Question about Kohler Home
Will not fully flush - Kohler Home
    Sergeant:
  • 316 Answers
Try a plunger.
Posted on Oct 04, 2009
Please insert your originals into the automatic document feeder hp 3052
It is looking for a document to scan. Either a copy job was started and interrupted or the device is not sensing a document in the adf. If scanning, ensure document is flushed and is fully inserted. If not scanning, cancel all jobs. If scanning and document is flush and fully inserted, check sensor/flag which may need replacement if all else is good.
Feb 21, 2015 | HP LaserJet 3052 All-In-One Printer
Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
WASH YOUR HANDS THOROUGHLY afterwards.
Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
Flush clogged heater core
A quick check of the heater core is to feel both heater hoses after the engine has fully warmed up. If both heater lines are hot, the coolant is circulating. If one feels cooler than the other, flushing it backwards with a low volume garden hose might help, unless there is a water valve in one of the lines that is closed-only some have a valve, not all cars. Pull the hoses off and try it. Some have even used an air compressor blow gun. If a lot of crud comes out, you may have fixed it.
Sometimes, the older cars get, the rubber seals on the heater case deteriorate, so cool air can sneak in and the heater just doesn't work as well. Big job to fix that. Try flushing the core if you think it needs it, and check heater case doors operation-maybe the temperature blend door is not opening fully.
Dec 26, 2013 | Saturn S-Series Cars & Trucks
I have a 1981 Yamaha XJ550 Maxim and my problem is that the bike has not been on the road in a number of years, but I added new brake fluid and bled the front brakes. The front brakes are not releasing...
Completely flush the brake system. That may help. Otherwise, you're going to end up rebuilding the calipers. Brake fluid is a magnet for water, and allowing a brake system to set can let things rust up.
To flush the system, attach a hose to the bleeder zerk, feeding it into a clean coffee can with just enough fluid in it to cover the bottom of the hose. Open the zerk at least a full turn. Open the cap on the reservoir, then slowly pour fluid in, allowing it to run through the system and into the can. It may take a full can, or more, of fluid to fully flush the system.
If that doesn't do it, as I said, you're going to end up doing a caliper rebuild.
Good luck.
Jul 06, 2011 | Yamaha XJ 650 Motorcycles
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Jan 15, 2011 | American Standard Home
The toilet does'nt have the same flush pull taking a couple of flushes very slow draining
Check the following: Is the water level in the tank properly set? Is the flapper valve opening fully when flushed? And is there any blockage in the waste line? Use a plunger to try and clear the line if the first two items are OK.
Apr 24, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
2005 R6 has been sitting for a long while like couple years. Now it will not start, Battery fully charged up. it turns over but no start suggestions?
you need to flush carb's/tank out of old fuel
if still no starts after flushing clean carbs main jets with copper wire strand
Jun 06, 2009 | 2000 Yamaha YZF-R6
TOILET WILL NOT FLUSH FULLY
pour some CLR into an empty tank - allow one flush and let it sit for a day then fill tank and flush again. hard mineral deposits are clogging the holes.
Mar 11, 2008 | Tecnik TKL9260 Front Load Washer
Home Logo
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
