Question about Frigidaire ATF6000ES Front Load Washer
I need instructions for instalation of the stabblising pins and attaching parts for transport of washer
  • 909 Answers
It is very difficult to replace the transport bolts, it's far easier to pack pillows or old blankets beside the drum from underneath.
Posted on Oct 04, 2009
How to install. A snow plow and ordering a couple of parts for it
From the part numbers you post I gather it is a John Deere equipment and your local JD dealer will be your best bet getting instructions and parts for that snow plow.
Jan 01, 2015 | Garden
Parts
With Sony parts being the way they are, you are better off going to the hardware store getting some brass or aluminum rod and using epoxy or the method that needs to be used to attach it to get the job done.
Sony threw more parts away and in a case like this they may want to sell you an entire transport. This is the way they do business.
Mar 12, 2013 | Sony TC-WE475 Single Cassette Deck
Details dimensions of clothes washer for the bleends at the back for ducting porpose.
Factory-supplied
equipment
There is a packet of accessory parts supplied with your washer. Check that all the accessory parts supplied for your model are there. If any parts are missing contact
your dealer immediately.
Inside the drum
Water supply hose for cold water (blue marking).
Water supply hose for hot water (red marking).
Water drain hose.
A bag which contains
Covers to be placed over the holes for the transport bolts (after removing them).
Clamp for drain hose.
Wrench for levelling.
Elbow for attaching the drain hose, e.g. to a sink.
Depending on the type of connection, the following may also be required
Y-connector (can be obtained from any hardware store) in case there is only a cold water
connection available.
Any residual moisture inside the drum is due to the final testing which every washing machine
undergoes before leaving the
factory.
On the rear of the appliance
Power cord with plug.
C = cold water connection
H = hot water connection
Useful tools
The following tools are helpful
Box cutter.
Flat head screwdriver.
Closed wrench (1/2"/13mm).
Bubble level.
Dimensions
a = 27.0 inches (686 mm)
b = 30.7 inches (780 mm) c = 37.0 inches (940 mm) d = 16.0 inches (407 mm)
Door opening angle 180
Approx. weight = 220 lbs (100 kg)
Installation area
DANGER
Never ground the washer to plastic plumbing lines, gas lines or hot water pipes.
Appliance stability is important, otherwise the washing machine could "walk" during the spin
cycles.
The installation area must be solid and even. Soft floor surfaces, such as carpets or surfaces with
foam backing, are not suitable.
If the washing machine is to be installed on a weak wood floor consider the following
0 If possible, place the washing machine in a corner of the room.
0 Screw a water resistant wooden board (at least 3/4" thick) to the floor.
0 Secure the feet of the washing machine with holding brackets. Order the holding brackets (set)
from Siemens Customer
Service (WMZ 2200).
Pedestal Mounting
If mounting the washer on the Siemens pedestal (accessory
no. WZ20395) follow the instructions supplied with the pedestal.
if Install pedestal prior to removing transport bolts.
Closet
If installing the washer in a closet,
observe the minimum distances according to the following table
Minimum Installation Clearances
Closet
Sides 1/4" (6 mm) Top 12" (305 mm)
Rear 2,5" (64 mm) Front 1/4" (6 mm)
Ventilation
Top 48 sq. in (310 sq. cm),
Bottom 24 sq. in (155 sq. cm)
Jan 03, 2011 | Siemens WFXD5200UC Front Load Washer
How do you service elite for transportation
Transport pins that lock the basket in place.
That is all.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I am looking to buy a used 4 year whirlpool duet washer and dryer. Do you need transport bolts to move either? Also what capacity is the washer and dryer
The transport bolts are required to be installed before transporting the machines. This is to support the suspension system to prevent damage to the machines during transportation.
The washer has a capacity of 9.0 kg or 19.8 lbs with a volume of 3.7 cubic feet. The dryer's capacity is 7.0 cubic feet.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Moving across country. Want to know how to safely move my whirlpool duet washer. Have original huge screws. What to do with them?
The large screws you mention are called shipping (or transport) bolts. They need to be installed prior to moving the washer to prevent damage to the drum, drum supports or counter-weights. They are inserted in the back of the washer. There are some small white plastic transport covers that you will need to remove to see where the screws insert. You can view an exploded view diagram of your washer at pcappliancerepair.com. The transport covers that I am describing are listed as item 26 under the "Top and Cabinet Parts" section.
In addition, its a good idea to remove any residual water from the wash tub and drain lines. If you own a wet/dry shop vac, an easy way to accomplish this task is to remove the drain line from the stand pipe at the wall and pull a vacuum on the line. This will pull any water that remains in the washer. This water can become stagnant if the washer remains closed up for any significant period of time. If you do not own a shop vac, an alternate method is to remove the clean out trap on the drain pump. Be prepared to place some towels down around the pump to catch any water. To access the drain pump, remove the toe panel directly below the washer door. This is done by removing the screws under the bottom front edge. With the screws removed, the panel will drop down, then come off.
NOTE: For better access to the panel screws, you can prop up the two front feet of the washer (a 2x4 works well for this).
The drain hose normally has a plastic saddle bracket that helps the hose keep its shape. On that bracket is a screw hole. Remove one of the top panel screws in the rear of the washer and reinstall with the drain hose bracket attached. This will enable you to ship the washer with the drain hose affixed to the back of the unit and not dangling.
When removing the fill hoses, leave them attached to the washer and tape them to the back panel of the washer. Or, remove them and place them inside the wash tub for safe keeping.
I hope I've given you enough information to assist you with your move. If you have any further questions, please let me know. I hope this helps you.
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Repair do it by myself
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 05, 2009 | Kenmore Elite 45986 Front Load Washer
Brass cotter pins an plastic catch tubes???? Kenmore washer 110.92597210
This is an easy one to solve. Those are moving pins , when in transport. When it is delivered, the delivery people simply just pull on some straps and the pins fall in the cup. You need to keep these when moving washer to put back in, so not to damage anything.
Sep 25, 2008 | Kenmore 23822 Top Load Washer
How do i take off the disc brakes on my 2001 toyota celica?
These instructions came from Auto Zone's website and their free, online repair guides. Just plug in your make, model and year and you can get exact instructions and pictures for your repair. Sweeeeeeet! Good Luck!
  1. Loosen the wheel lug nuts slightly.
  2. Raise and support the vehicle safely.
  3. Remove the wheels.
  4. Disconnect the brake hose from the caliper. Plug the end of the hose to prevent loss of fluid. Some brake lines have a union bolt and gasket type line attached to the caliper. Do NOT lose the washers.
0900c152801a856d.jpgRemove the brake hose union bolt with gaskets from the caliperHave a container handy to catch brake fluid from the disconnected lines.
  1. Hold the sliding pin and remove the bolts that attach the caliper to the torque plate.
0900c152801a856e.jpgRemove the two bolts that attach the caliper to the backing plate
  1. With two hands, lift up and remove the caliper assembly.
To install:
  1. Grease the caliper pins and bolts with Lithium grease or equivalent. Temporarily install the caliper on the torque plate with the installation bolts.
0900c152801a856f.jpgThe sliding pins should be greased with Lithium-based grease before installation
  1. Hold the sliding pin and tighten the installation bolts to 25 ft. lbs. (34 Nm) on the front wheels, and 14 ft. lbs. (20 Nm) in the rear.
  2. Attach the flexible brake hose to the caliper with new gaskets. Tighten the hose to 22 ft. lbs. (30 Nm).
Install the brake hose lock securely in the lock hole, in the caliper.
  1. Fill and bleed the system.
  2. Install the wheel, lower the vehicle and tighten the lug nuts.
  3. Before moving the vehicle, make sure to pump the brake pedal to seat the pads against the rotors.
  4. Check for leaks.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove the wheels.
  3. Disconnect the brake hose from the caliper.
  4. Remove the bolts that attach the caliper to the torque plate. If applicable, hold the flats of the sliding pin with a wrench while loosening the caliper attaching bolts.
  5. Lift up and remove the caliper assembly.
To install:
  1. Install the caliper and loosely install the bolts.
  2. Hold the flats of the sliding pin with a wrench, then tighten the bolts. Tighten to 25 ft. lbs. (34 Nm) except on Celica rear calipers. Tighten the bolts on Celica rear calipers to 34 ft. lbs. (47 Nm).
  3. Connect the brake hose to the caliper, using 2 new washers.
  4. Fill the brake system to the proper level and bleed the brake system.
  5. Add brake fluid to the reservoir to fill to the correct level.
  6. Lower the vehicle to the ground.
Jul 17, 2008 | Toyota Celica Cars & Trucks
Frigidaire ATF6000ES Front Load Washer Logo
91 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
