Question about Villeroy & Boch Home
My toilet is continuously syphoning, i.e. water trickling down the back of the bowl, I have replaced the dump valve seal to no avail, and now suspect the problem is with the mechanism that refills the cistern, becase apart from anything else, that's where the noise is coming from!
    Sergeant:
  • 316 Answers
When you lift up the float does the water cut off like it should? If so you might have your float level to high and its going over the overflow tube. Water needs to cut off before it gets to the top of the tube. Adjust float.
Posted on Oct 04, 2009
Not shutting off completely when flushing
You're to replace shutting valve.
Jan 25, 2018 | Home
Saniflo ball valve replacement
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Dec 29, 2012 | Saniflo SaniPlus-Round SaniPlus Macerator...
After automatic flush, water continuously runs into bowl. The water is coming from the upper bowl above the wand area.
i would think the syphon is not closing after the flush, so as the cistern fills it just runs straight into the pan. you'll need to replace the syphon...
Jul 07, 2011 | TOTO MS990CGR Neorest 600 One Piece...
Replaced the seals because it was running. Water is still leaking from the tank somewhere so it keeps refilling....it's constantly leaking and refilling. how can I repair this.
You say you have replaced seals. I assume that you are refering to the flaper valve that controls dumping water from tank to bowl to flush. To make sure you have a good seal put a dozen or so drops of food coloring directly into tank when it's full and observe for a hour or so to see if water in bowl is discoloring. If it is then you are still leaking there. You can shut off water supply off or flush toilet and manually hold flush valve closed. Check to see if there are any rough spots on flapper seal that could stop flapper from sealing good. If you find rough spot then make sure the surface is dry and sand lightly with medium grit sandpaper.120 grit or finer.
One other thing to check is if your toilet has the plastic or rubber tube that goes from the flush valve into the overflow. Make sure that this tube does not set below water level in tank when it is full as this can create a suction or syphon,
Hope this helps you. Thanks
Jan 10, 2011 | American Standard Home
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Toto flapper seems ok but toilet keeps slow trickle into the bowl
The water inlet valve should close completely and stop water from coming into the tank before the water level reaches the "small tube." (This is the overflow tube.)
There may be an o-ring or rubber gasket inside the valve that can be replaced. If not, you would have to replace the water inlet valve.
Oct 16, 2009 | Home
Water overflow from cistern to bowl after flushing the water keeps going into the bowl where is the water shut off valve on these toilets?
The shut off valve depends upon where your plumber fitted it and whether one was installed at all. If there's not one near the cistern then you'll need to find the stop valve which is on either the main household cold water tank outlet or if the cistern is filled directly by mains water then you'll need to turn off the main supply valve or even the valve in the street.
The fault is caused by a failed syphon assembly inside the cistern. Although it's possible to remove the faulty part and replace it the sheer number of different syphon assembly designs and the age of many of them usually mean that it's quicker and simpler to replace the entire assembly. Without knowing exactly which make and model of syphon you have it's impossible to give you any more specific details as the operating methods vary so widely, but if you're mechanically minded then you may well find that you can dismantle the old syphon and locate the failed seal. Sometimes all you need to repair them is an old car tyre inner tube and a pair of scissors. A repair often costs pennies and takes hours, a complete replacement syphon assembly often costs between £13 and £60 depending on the model and design (plus labour) but usually takes no more than around fifteen to twenty minutes to replace if the cistern is close-coupled to the toilet and a bit longer if it's an old-fashioned high level cistern with restricted access.
Given the need for guesswork based on the limited details in your question I hope that you appreciate my reply and ask only that you return the favour by rating my answer.
Oct 01, 2009 | Home
A. S. Colony toilet
hi,on some of these syphons there is an adjustment on the syphon itself ,they are easily removed usually by a qtr turn to the right,failing that it will be the rubber seal at the bottom of the syphon.
Oct 25, 2008 | American Standard Colony 2388.012.222...
Home Logo
928 people viewed this question
Top Villeroy & Boch Home Experts
Oloyede Monsuru
Paul Carew
J.D. Browning
J.D. Browning
Are you a Villeroy & Boch Home Expert? Answer questions, earn points and help others
