Question about Sony Playstation 3 (PS3) Console
My PS3 was working yesterday, went to switch it on this morning the light just flashs red, my game is stuck also hope u can help, Thanks John
  • 85 Answers
This is a serious problem, similar to the xbox red ring of death. Check out playstation forms: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=905486
Posted on Oct 04, 2009
PS3 switched off during use, Red light flashing at front,can't get game out.Tried switching on while holding disc removal button,that did not work,left unit overnight to cool down,tried it again and it...
Sounds like a heat problem. You can either send it to sony and get it fixed for about $50. Or check out this youtube video below which has help many people through this problem.
Hope this helps, Nathan Taylor
Jul 18, 2011 | Sony Playstation 3 (PS3) Console
PS3 switched off mid game, red light illuminated, touched on sensor green light illuminated for about 5 seconds then went back to off, red light again.
If the system flashes both the red and green light together, making a sort of yellow color, the system has overheated, and one of the main chips has become defective or detatched. This problem is known as the "Yellow-Light-Of-Death". If the system is still under warranty, contact Sony, and they should replace or repair it for you. If not, they will still repair it, it will just cost more, if the warranty seal is still intact. Hope this helps!
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
My ps3 shut off and I tried to turn it on again and it beeped 3 times, the power button went red,yellow and blue then shut down. After all that it still flashes red and does not turn on. I also have mw2...
Make sure that your PS3 is not put in an air tight space, direct sunlight, or heated room where it overheats. Put it in an open space, and make sure that there's sufficient air flow. Otherwise, You'll get the 'yellow light of death' Hope this helps.
Aug 24, 2010 | Sony Playstation 3 (PS3) Console
PS3 Stopped working, now just flashes yellow, or red
this si called the RLOD or the red light od death and is caused by the following
1. overheating
2.your hardrive is corrupted or needs to be reset into the system
3. the soldering on the motherboard needs to be reflowed and can be repaired at any local repair shop tha tspecializes in the PS3 gaming console
hope that i could help!!
Jul 23, 2010 | Sony Playstation 3 (PS3) Console
Ps3 red light flashing and won't turn on it was working fine yesterday
ps3 power up green light comes on then gos red flashing will not eject game
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
PS3 can turn on, but T.V screen is black
turn power switch on in the back. red light on in the front, hold the power button until system turns back off. this resets all hardware settings. if this doesn't work and the system is ok (green light) then you have a connection problem to the tv
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
Controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
