Hoover wdm130 washer dryer wont spin the brushes were ok and have replaced with new also
3 Suggested Answers
SOURCE: hoover washer dryer saver 1300
I have exactly the same problem on the same washer , but know just will not spin so called a repairer and waiting for them to call me back
Posted on Jul 25, 2008
blueextc3221
  • 15935 Answers
SOURCE: My machine wont spin and leabes brown marks on clothes
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I have a hoover saver1300 as from today it doesn't spin. It seems to pump ok but spinning is a nono. Please help, Im desprate. Cheers Stacey
Hi Stacey, Seems like your carbon brushes inside the motor may be worn out or sticking.Is the drum turning ok on wash? To check the brushes you will need to remove the motor which nis situated at the bottom of the machine.I dont know if you will risk this yourself, but if so ensure machine is unplugged. Remove back panel, then remove belt, and bolts holding motor into place. There is then a plug on motor which needs to be removed and also the green and yellow earth wire. The carbon brushes are at the side of the motor, in a plastic casing. they will have just 1 wire to each, and will be held in place with 2 screws in each. There are 2 brushes 1 each side of the motor. they should be at least half inch long, and slide in and out of plastic casing freely. If these need replacing then any domestic spares shop should stock them at around £12.- £15.00.Good luck and just be careful as the motor is awkward if you have never seen this
Mar 12, 2010 | Hoover H120M Front Load Washer / Dryer
The brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Aug 19, 2007 | Equator EZ 3600 CEE Front Load Washer /...
Hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Aug 14, 2007 | Hoover AL130 Front Load Washer
Washing mechine 1200 hoover
Hi, It sounds like it might need new brushes in the motor. Sometimes just before they wear down completely, they will wash but not spin, this is because the spin needs more power. Tom.
Mar 12, 2007 | Hoover H120M Front Load Washer / Dryer
Hoover WDM120
this will be your carbon brushes which are situated at your motor in a plastic cover with a wire is attached if these are low then it will not spin must be at least 8ml long for it to work they start off about an 1inch in length
Nov 14, 2006 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
