Does not open/close; or power on unless I plug out the power cord & plug back in. Lately, even that is not working. Does not recognize discs it used to play alright before. Says "No Disc" - erratic. Does not open/close; or power on unless I plug out the power cord & plug back in. Lately, even that is not working. Does not recognize discs it used to play alright before. Says "No Disc" - erratic.
Have the same problem as chaise718. DVD player is stuck in standby(red) mode an will not snap out of it despite cyberhome's solution of turning off the unit or hitting the standby button on the remote.Have the same problem as chaise718. DVD player is stuck in standby(red) mode an will not snap out of it despite cyberhome's solution of turning off the unit or hitting the standby button on the remote.
You can't post conmments that contain an email address.
Step 1: Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2: Press and release the Power button.
Step 3: Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4: Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
THis one should be easy--just read it in the manual--reset your video mode by removing any disks from the player, close the drawer, and then press and hold the "stop" button for five seconds. The green power button should flash red and back to green. Hope that solves it.
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600 into a Region Free DVD Player There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding CH-DVR 1600 MU
Power Up the unit with NO Disc in the tray.
Press the Setup button on your remote control
Press the 1 button on your remote control
Press the 6 button on your remote control
Press the 9 button on your remote control
Press the 5 button on your remote control
Press the 8 button on your remote control
Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
Exit the menu
Press the Power Off button on your remote control
Press the Power On button on your remote control
CH-DVR 1600 ZU
Press the Red Record button on your remote control
Press the 0 button on your remote control
Look on the bottom of your player. Between the two front feet you should see a narrow slot that is about 1 1/2" long (it should say "emergency hole". Shine a light into the slot, you should see a black pin about as big around as a pencil lead. Carefully push this pin in the direction of the arrow. It should release the drawer and allow you to open it.
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Hi kjflynn06
let your DVD player stand for about 2 days then you plug it in back if that does not work call a tech could be a faulty power supply good luck.
