Question about Fuji FinePix A700 Digital Camera
After taking picture write error appears - Fuji FinePix A700 Digital Camera
Read error appears after downloading pictures and looking back in the camera, some pictures have read error
When you hook your camera to your computer you are accessing it like a disk and changes made to "files" are saved to the disk. A common change is to rotate the image so it views correctly on the computer screen for images you turned the camera to take a portrait oriantation shot. That change is saved to the image on disk, then the camera can no longer display it because it is not the right "dimensions" for the camera (it is rotated)
Dec 13, 2011 | FUJIFILM FinePix S2950 / S2990 Digital...
Unrecognizable file format
In your camera settings menu, there is probably an option for you to switch the different kinds of file formats that the pictures are saved onto your memory card as.
Your memory card might not support certain file types.
Apr 09, 2010 | Kodak EASYSHARE M1063 Digital Camera
Whenever i take a picture and press to review it says file error
Hello!!
Try formatting ur memory card once and reload it ...
Apr 20, 2009 | Samsung Digimax S630 Digital Camera
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Memory card error
did you buy the camera new?
Mar 17, 2008 | Samsung Digimax S730 Digital Camera
Error 99 on 30D Canon
Had this problem before and i found this guide online
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Feb 22, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
I have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Error message to turn camera off and then on again
Have you tried taking the card out and removing the battery and trying again. I had an issue with one card - no different from the others I use Scandisk 2GB but problem has now gone.
Jan 29, 2008 | Panasonic Lumix DMC-LX2 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Fuji FinePix A700 Digital Camera Logo
15 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
