Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Flashing red lights
I just had the lamp replaced by TV repairman that cost$ 400.00and he say what ever make the lamp run is broke now he said a light engine and that why it is still flashing red i want to price one
Unplug the tv for a couple of secs.
Bob
Posted on Jan 09, 2008
It might be you light wheel.
Bob
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
My Sony LCD rear projection tv model KDF-55WF655 won't come on. Instead the red lamp light comes on. What can I do ?
Red lamp light indicates that tv needs lamp replacement as existing lamp in tv is dead/ broke.
Lamp replacement procedure is written in user manual of tv.
Thanks.
Apr 28, 2011 | Sony Televison & Video
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
A large cracking sound, tv went out. Green light "on" button flashed off and red lamp light come on. No sound or picture
Lamp is broke in your tv, replace it to get tv back in working, lamp replacement is easy and user level job, details are mentioned in user manual.
Thanks.
Sep 28, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The tv Sony kdf-42we655 will not turn on, the light will flash green and make a humming sound but thats it, the light below that labeled "lamp" flashes red? Why is the tv not working properly and why is...
Your tv is a projection one - it uses a very powerful lamp/bulb to generate the light that used for the image. In your tv that bulb has died and must be replaced - it will cost about $200.
Jul 05, 2010 | Sony KDF-42WE655 Television
My TV just stopped and the led light on the front is flashing red. A repairman said I need a new transformer and the power supply must be repaired costing more than &400.00. Could it only be a fuse or...
A flashing red led means that the power source goes in and out of protected mode = something massive has been fried in it. The repairman is most likely correct.
May 23, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have sound and no picture. Red light on in front of tv indicating lamp. Can be fixed w/o repairman?
Yes the Lamp can fail within that time frame. Much of it depends on how many hours the set is running. Most Lamps have a 3000 to 5000 hrs of life. But with any Halogen style Lamp, this is not written in stone.
Hope this helps,
Skyassoc
May 11, 2009 | Mitsubishi WD-65833 65" HDTV
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Green light flashing & no picture on Toshiba 40pw13p
There is problem with the lamp. It might need to be replaced. The lamp unit is on the bottom-left side of your TV. Loosen thumb screw (by hand) to take the the lamp unit door. Using a screwdriver, loosen two screws of the lamp unit and carefully pull the lamp unit out.
Put a new lamp in reverse order.
Jun 28, 2008 | Televison & Video
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
