Question about Sony PlayStation 2 Slimline Console
I'm a dumba$$ . . . I removed the reset/open power ribbon
Ok . . . as I said above, I have one of the older PS2s and it runs on a ribbon for the power and response for the reset and open buttons. Problem is, I have no idea the proper way to install it again, nor do I have the money for a repair guy. If anyone can shead some light . . . PLEASE DO SO!!!!!
    Problem Solver:
  • 12 Answers
Well, if the ribbon conductor is broken, cracked, or otherwise messed up, i dont think there is anything you can do. however, i think it runs (fold it along the old crease lines) under the disk drive and to the mainboard of the ps2.if you can find the ribbon connector that it hooked to, it *should* be a piece of cake as long as you fold it back the way it was folded. if you are still having trouble, update the question with specifics and i will do my best to help you.
Posted on Dec 27, 2007
C1AB0001 ERROR IN HP 8038 PRINTER
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Mar 11, 2013 | HP PhotoSmart Office Equipment & Supplies
My Sony mhc-ec79i is displaying PROTECT on the screen can't do anything while this is up, please help
Open the back of the unit and remove the 5way ribbon and 7way cable plug from the main amp module and turn on power the LCD should display normal operation, then power doen and refit those plugs and repower again and all should be ok now, simlpy by turning of the power does not reset these units you have to remove these leads to force reset, check theat the fan is not blocked with dust and thbe speakers are ok and no shorted wires etc and the impedance is ok.
May 25, 2011 | Audio Players & Recorders
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
Printing problem hp D7160 error 0xc18a0001 please help
Hi,problem can be solved .Please check out this link for the Ink System Failure problem.
fixyourownprinter.com/forums/printer/39471
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Our HP 3310 was having the same ink system failure. Tried everything I could find, and had just about given up when I found this forum. I didn't quite get the reset right the first time, but on the second try it worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
Also
Hope this works for you. Please let me know.
Oct 28, 2010 | Office Equipment & Supplies
I have a IBM Model 5651 Memory Typewriter (Selectric II carriage), and I cannot make the ribbon advance while typing. If I turn the ribbon it will type until the ‘ink’ runs out. It’s just not advancing. ...
If this takes a selectric II ribbon the Spiked driver may be gummed up. Remove the ribbon,
find the latch that holds the ribbon mech. open, release it the ribbon drive should swing freely to the right, if not spray some WD40 on the pivot point, above and below the arm then work it back and forth it should free up.
DickyO
Oct 25, 2010 | IBM Office Equipment & Supplies
LG VX5300 Flip Phone broke in half.
Your phone can work again, all you need to do is to get the flexi cable and fix it back in place.
It is not expensive.
It is about $15.
To fix this, these are the processes to follow;
  1. Get the appropriate screwdriver,
  2. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery.
  3. Next remove the 2 rubber stoppers and unscrew the aerial.
  4. Remove the 6 screws,
  5. Next remove the 2 rubber stoppers & screws above the main screen,
  6. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  7. Unclip the ribbon,
  8. After removing the ribbon cable, carefully lift the metal part that is beneath the phone. Another ribbon will be attached which should be carefully removed.
  9. Take the circuit board & keypad out and you'll be left with what's below it.
  10. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  11. To open the top half of the phone and get to the screen, run your fingernail between where the two parts of the housing meets,
  12. Try to open up the top part by splitting it open with a credit card,
  13. replace the ribbon and,
  14. Reverse the procedure for reassembly and it's finished.
Take care
Jun 21, 2010 | LG VX5300 Cellular Phone
PS 2 new and old games keep freezing
It needs a new laser... it's a pretty common issue with older PS2s. The lasers simply eventually wear out after time. You can get a new laser for the older PS2s at the following website:
http://store.richspsxparts.com/newpl2lakhv.html
May 15, 2010 | Sony PlayStation 2 (PS2) Console
Same problem. All other new games load. Madden 2010 loaded. Three guitar hero 5s wont load nor will they load on my three friends ps2s. All games were purchased at wal-mart! Wal Mart will not give us our...
My friend bought guitar hero and we tried to play it on my older ps2, would not work. They went and bought a brand new one from walmart and it works fine. I guess it is something with older ps2s
Oct 29, 2009 | Video Game Consoles & Games
Original playstation 2- 8 years old- wont read discs.
It's a laser issue. 8 years is a long time to get out of your PS2! A lot of people's PS2s start failing within 2 or 3 years. The lasers are pretty unreliable on the PS2, especially if you use it as a DVD player. The following website sells lasers for the older PS2s and also performs repairs. However, it's a bit expensive. More than half of what you can buy a Slim PS2 for new.
I would strongly suggest, however, that you stay away from used or refurbished PS2s for the same reason! You have no idea how much life the laser has left. Either go with a brand new [not refurbished] laser in your PS2 or buy a brand new [not used, not refurbished] Playstation 2.
Oct 21, 2009 | Sony PlayStation 2 (PS2) Console
Toshiba screen goes blank when it is opened too far
Sounds like a problem with the ribbon for the screen being either having a loose connection or getting nipped. Pretty common on laptops because the ribbon runs along by the hinges on the base and then up to the screen.
Hopefully you will be able to access the ribbon on your model by removing the plastic bezel which lies just above the keyboard. The ribbons I have seen are about 1/2 inch wide and as I said connect on the base and the screen. The connection just pushes in. If its loose at the connection on the base then obviously push the connection fully home. If it's getting nipped then reseat it so that it does not get caught. ***NOTE*** a problem could arise if the ribbon has actually been damaged from being nipped - opening the laptop could cause it more damage and then you could lose the screen until you replace with a new ribbon. These can normally be purchased on places like Ebay and don't cost an arm and a leg.
If this helps, I'd appreciate feedback so other people can use this as a solution. Thanks
Nov 22, 2008 | Toshiba Satellite M65-S9092 Notebook
Sony PlayStation 2 Slimline Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
