Question about Whirlpool 24 in. ADG7540 Built-in Dishwasher
Start light flashes 6 times - Whirlpool 24 in. ADG7540 Built-in Dishwasher
  • 4 Answers
6 'start' led blinks indicates
WATER TAP CLOSED
Water walve is switched on but flow meter sends no impulses or sends less tan 10
impulses in 10 seconds and the water indicator is off (empty)
posible reasons:
water tap closed
water inlet hose closed
water inlet valve defective
flow meter defective
remember to unplug it from power if any repair is done
Best regards and good luck
Posted on Oct 04, 2009
I had my Smartstart intalled by a dealer. They were able to get the doors to work. but Directed to d them if the doors work then my engine should start after I activate my subscr iption. Well I did and it...
The multiple flashes of the parking lights are shutdown diagnostics:
1. 1 flash is runtime expired
2. 2 flashes is over-rev shutdown
3. 3 flashes is low or no rpm (tach wire)
4. 4 flashes is transmitter shutdown
5. 5 flashes is + brake shutdown
6 6 flashes is - hood shutdown
7. 7 flashes is timer mode/turbo mode manual mode error
8. 8 flashes is neutral safety shutdown ( the remote start control switch is in the off position).
9. 9 flashes is low battery (voltage setting)
10. 10 flashes is alarm triggered
11. 11 flashes is wait-to-start input timed out.
Hopefully, the above mentioned diagnostics will help you determine why your remote starter is not working and you will begin to enjoy the system.
Nov 25, 2010 | Viper SmartStart Module
Green timer light blinks and then lamp light blinks.. tv will not start up.
You probably need a lamp. Check the code by holding menu and input for 5 sec. If you need a lamp the led will flash 6 times pause then flash 6 times again. The code will repeat several times if you miss the first few flashes. If the code is different, let me know what it is and I can help you. Thanks.
Jul 05, 2010 | Mitsubishi WD-65733 65" HDTV
Power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
Feb 16, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Dishwashers Logo
688 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
