I have just replaced my HVAC Control board &
I have just replaced my HVAC Control board & I'm not getting and power throught the board to my thermostat. Also I'm getting a flashing code in the board thats not related to my HVAC unit. Orginial Board # 50A55-571, Replacement Board 50-A55-843. Instructions state the new board replaces the old one. Flashing Code is 5 flashes meaning ''open rollout switch. My unit doesn't have rollout switch. I have a American Standard, model # CUB100A948C1. They give you a jumper wire for the 12 pin connector if your unit is a Trane for the rollout switch. I tried that and still the same code and unit won't run. Thermostat blank and the fan just runs constantly while the board flashes 5 times. I feel I'm missing something like a jumper wire or ??? any suggestions?
  • 80 Answers
Once you have installed the jumper, you will need to kill power to the furnace for about a minute to reset the board. Make sure the the jumper is making good contact. Sometimes they appear to be plugged in but still are not making contact.
Posted on Oct 04, 2009
What fuse goes to the ac/heater fan in a 2004 Buick Rendevous
https://s4.postimg.org/m2cv5i825/hvac.jpg
Click on the link
See ign fuse 3--40 amp toward the right, in power distribution center under the hood, it sends voltage to blower motor control module. The two fuses toward the left, among other places, sends voltage to hvac control module. I looked up info for automatic hvac. Are there any applicable hvac trouble codes? At the moment, I can't rule out the blower motor itself?
Jul 11, 2017 | 2004 Buick Rendezvous
What would cause it to die when I turn on A/C or heater?
Start by checking power an grounds at the control panel ,you'll have to take the plastic trim panel off to get the control panel out . You could have a bad HVAC panel ,
HVAC Control Module
The HVAC control module is a class 2 device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive voltage circuit provides power that the control module uses for keep alive memory (KAM). If the battery positive voltage circuit loses power, all HVAC DTCs and settings will be erased from KAM. The body control module (BCM), which is the vehicle mode master, provides a device on signal. The control module supports the following features:
Dec 17, 2015 | 2004 Chevrolet TrailBlazer
Where can I get the heat control wiring diagram?
How do you know there is no B+ voltage ? Did you check with a volt meter ?
Red with white stripe wire gets power from AIRCON fuse 15amp I/P fuse box.
HVAC Control Module The HVAC control module is a GM LAN device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive and ignition 1 voltage circuits provide power to the control module. The control module supports the following features:
Is your HVAC manual or automatic ?
Is yours
Nov 26, 2015 | 2008 Saturn VUE
The control board keeps getting hot after about 30 minutes of running the engine
control board huh?
where are your hands, in car , under car, under hood
where? if you dont know?, post a photo.
how hot, 100F , 200, 300?
hotter than bath water, or boiling hot, or smokes?
PCM
TCM
ABS
NAV
radio
head end audio or amp?
Hvac controls
Jan 24, 2015 | 2006 Toyota Corolla S
I am installing a S1-43101972100 control board to replace Evcon 2702-310/A. Where do I connect the M1 wire from the blower motor and where do I connect the COM & 24VAC wire on this board?
There is a wiring harness for this conversion. i have included a link to a source. It may be difficult to find a schematic to make this conversion and safer to use the harness. Control Board S1 43101972100
May 15, 2014 | Heating & Cooling
HVAC Blower stopped working
The fuse you replaced powers the hvac control. The run relay is powered by a 30amp fuse in the fuse box near the battery.
Is the relay getting power from that 30amp fuse ?
Jul 10, 2013 | 2004 Saturn ION
My fridge just stoped working. i have checked power to the cooling system and get no power. i checked power to the (mother board) i get power all the way throught till i plug in the connecter to the...
it is or may be the mother board . very common . ck the printed pc board . it may have a bad soder joint .. very common .. .. most no go like yours are the pc control in the back . mm hope this helped feed back pls ..
Sep 19, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Blower fan only works on high
CHECK THE HVAC CTRL FUSE.
WITH A TEST LIGHT CHECK THE BLOWER RESISTOR FOR POWER ON THE YELLOW, TAN, PURPLE, AND LIGHT BLUE WIRES. THE ORANGE WIRES CONTROL THE HIGH SPEED CIRCUIT. DO THIS FOR EACH POSITION OF THE BLOWER SWITCH.
THE BROWN WIRE ON THE HVAC CONTROL CONNECTOR 1 POSITION B COMES FROM THE HVAC FUSE 20 AMP. NO POWER ON THAT WIRE WILL CAUSE THE BLOWER TO NOT FUNCTION ON THE LOWER SPEEDS.
Jul 14, 2009 | 2000 Pontiac Grand Prix
Bass amp power's on but blows speakers
There is a problem with your power cicuit board that causes high current to pass throught to the speaker's PC Board circuits. Ask a technician to troubleshoot the PCB circuit for defective components.
Nov 09, 2008 | 3Com SuperStack II advanced RPS...
Heating & Cooling Logo
284 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
