Question about Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Fuzzy photos despite advertising otherwise, I get a lot of fuzzy photos and often very dark shots. Is there a particular setting I need to change
Mitsubishi TV Model TS-4557 Two problems: 1) The picture is very dark despite the brightness control being at the maximum. 2) The picture is fuzzy - particularly when there is text on the screen, to the...
the problem is picture tube base which connects picture tube to circuit board ..inside ur tv..take tecnical help of service men to replace the p.t.base
Mar 13, 2010 | Mitsubishi TS-4557 45" TV
Hi, when viewing my ldc screen to take a photo its dark, cloudy and fuzzy. I can't view anything.
I have a good news for you. Probably the CCD imager is bad, it could be FREE repaired by SONY service center! Look for your local SONY serv.center.
Aug 29, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Trouble taking night time photos
Please go to camera menu and select Initialize and press OK to RESET camera to factory default settings.
I hope problem will resolve.
Feb 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Focus is fuzzy
Dear ninimarion
Try to change the different settings on the camera and yet if it doesnt work, u can get assistance from a photo studio in ur locality they should set the settings for u or exactly say if it is a internal fault.
Dec 09, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
All photos underexposed, changing settings does not help
defective shutter curtain opening, it needs pro service. Shutters have life expectancy around 5thou to 10 thou shots.
Jul 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
What are the normal settings for night shots on oly C3030Z. Shall I use flash when I shot on nights? If I set the aperture on F2.8 and the shutter from 2 to 16 sec. I got a lot of pixels on the...
There are ways to deal with this problem. As others have said, your camera appears to be normal. Consider using "dark frame subtraction" to successfully employ long shutter speeds. The technique involves capturing two images using the same exposure time and the same camera temperature. One of the images is your picture. The other (the "dark image") is captured with the lens cap on, or other suitable way to block all light. Then using one of the more sophisticated photo editing applications, "subtract" the "dark image" from your picture. This technique will dramatically reduce the noise, because moist of the noise is deterministic, but is highly dependent on shutter speed and on CCD temperature. Of course you can use flash at night, but only for subjects that are close enough to the camera - not for a subject such as your stjernehimmel 2 photo
Sep 07, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
One of the pictures has a great blue sky but the green tree is very dark and the other one has the green tree and very bright sky?
The two pictures were shot at dramatically different exposures - the "dark" one at 1/1600 shutter speed, f7.3, the "light" one at 1/320 shutter speed, f4.0. This accounts for the great difference, as the exposure conditions for the "light" one allowed much more light into the image during the exposure period. You didn't tell the whole story of how you set this up, I think you were shooting in a "spot" metering mode, where the particular exposure conditions the camera uses would vary considerably whether you were aiming at a dark area (making the picture light) or a light area (making the picture dark). I would make two recommendations: Switch your metering mode to "center weighted" (the mode labeled "[(•)]"), and also change your ISO setting to AUTO, as there would be no reason for shooting these photos at ISO 200 that I can think of.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Agfa FUJIFILM FINEPIX Z33WP Digital Camera Logo
18 people viewed this question
Top Agfa Cameras Experts
CHIVOIU...
CHIVOIU...
Are you an Agfa Camera Expert? Answer questions, earn points and help others
