Question about Nikon Coolpix 5600 Digital Camera
File cannot be read.
I took video, recording was fine until I stopped taking. Message came up: Card cannot be used. (I had been using this card since I bought the camera.) Check the card and the video file is in it but could not be open. How can I view the file now?
I took pictures and recorded video on a (PNY OPTIM SD HC [60 HD] ) Memory Card that a friend gave to me. and it recorded fine on my camera. I use a Nikon Coolpix, but yet nothing is reading the card. I...
It could be that the devices into which you inserted the SD card are not designed to accept SD cards of that type.
There are 3 SD card types: SD, SDHC and SDXC. If the SD card size is 4GB to 32GB, the type is SDHC, and if the card is larger than 32GB, it is an SDXC type.
Newer devices will accept SDHC and SDXC cards, but older devices may not be able to read those SD card types. You should be able to check the specifications of the devices you are using by looking on the device manufacturer's web site.
Sep 25, 2017 | PNY 2GB microSD Memory Card
This camcorder does not record video; it won't format memory card
do you get any kind of error code?what type of memory stick are you using?how big is the ms capacity?may need to try using a diff ms or try using ms with diff devices.if diff ms works fine.may need to format ms using computer first (using card reader if available) and camcorder last.may need to reset camcorder (make sure cam is on when you press the reset button.hope this works.thanks :)
Mar 12, 2010 | Sony Handycam HDR-CX12 Flash Media...
File error
I think you memory card slot in the trouble, if you have try to use another memory card and the result is the same. You can try to clean up your memory card slot.
Jul 24, 2009 | Samsung Digimax S630 Digital Camera
Problem with memory card
your camera can only read so many partitions
( File Allocation Tables )
( partitions are sections of the total volume )
Like slices of a cake.
which equals 4 GB, total.
so it will never be able to read more than this.
Like FAT32 on a Pc, will read 32GB
but you could have a 100GB hard drive in the machine, still reads 32GB only, so even on a PC 68GB would be wasted.
The file format on the camera can not change,
So you are stuck with 4GB max reading.
Hope this halps
Regards
Richard.
Oct 04, 2008 | Pentax Optio W30 Digital Camera
Kodak Easyshare CX7430 losses memory when shut off
I have the same camera and the same problem. Can't use SD cards anymore, only the obsolete Multimedia Cards that are extremedly hard to find on shops because SD cards are the substitute for them... hope you can find a Multimedia Card. At least mine works fine with them.
Jul 31, 2008 | Kodak EasyShare CX7430 Digital Camera
Problem downloading a video file from Canon Powershot S3 IS
Have you tried inserting your card into a USB memory card reader? simply take your card out and plug it in. The PC will read it as a drive and it's a simple drag and drop .
Dec 04, 2007 | Canon PowerShot S3 IS Digital Camera
Video and still image - SD Memory Cards
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher. *Usable capacity will be less. The use of SD Memory Cards other than the ones mentioned above may result in the following error message: [This card cannot record in MPEG2 mode.]
Aug 31, 2005 | Panasonic D-Snap SV-AS3 Digital Camera
"Recording stopped. Record in internal memory "
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Recording stopped. Record in internal memory"
This error message indicates that the memory card cannot be used to take videos. Change the storage location to internal memory. Use the memory card to store pictures.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon Coolpix 5600 Digital Camera Logo
49 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
