Question about Sony DAV-IS10 System
Volume Problem I just purchased this system and my volume control goes from 0 to 70. However, I must have the system up to about 45 before I can hear anything. I must have the volume up to 60 before I feel like it is just right. If the system is up to just about 68 is it considered loud. Is this an indication that the unit is defective? Or am I just missing something?
  • 1 more comment
  • momeijer Jan 03, 2008
    I have exactly the same problem here. Does someone have more info?
  • Natieamwong Jan 17, 2008
    I have the same problem. I don't want to un-mute the TV because it will be an echo.
    Another problem I have is it doesn't sound like 5.1 because the rear speakers are not loud even I calibrated them already. (I set up to PrologicII)
    Does anyone know how to fix the problems?
  • Anonymous Apr 27, 2008
    Same issue with my new sys but the sugested solution did not help.
Deactivate the the TV speakers, make sure that the TV isn't muted and Turn the TV volume up FULL..
Posted on Dec 27, 2007
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
Sangean ATS-909X Volume control has failed (no longer trims volume). A little pressure on the control will sometimes restore its function. Sounds like a bad solder joint or a cracked board. Any th
A similar problem with SANGEAN ATS-909x I have too.
When you touch the volume control ever hear the full volume.
Tap volume control side, the sound is normal.
Suppose a poor connection on the control volume.
Correction here in Slovakia is not guaranteed.
Receiver has a serial No: 0C000451 is under warranty, purchased through E-Bay from Taiwan, made 1/2011 and purchased in 2012.
It seems that I remains only a decoration.
Translation by GOOGLE
May 11, 2012 | Sangean ATS-909X Professional Multi-Band...
When volume goes high, the system goes in protection and relay's clik is heared
This is not the fault with remote control. Check the load connected to the device. If overload occurs, the device will itself go to protect mode. Disconnect speakers one by one and check which speaker box causes the system to go to protect mode, when volume is incresed. Check that speaker for short.
Apr 02, 2012 | Televison & Video
Hello, I have an RT 2870 RCA surround sound system. When I turn it on all I hear is static and its not until I crank the volume up to around 25-30 before I can hear the audio. How would I fix this problem?
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control (volume pot??) may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 24, 2011 | Audio Players & Recorders
Volume control problem.constantly having to ajust volume.have 2 volume control remotes; one is the vizio volume control and one is our cable company volume control. could their also be a setting in the...
Also have the same problem with ours - purchased a 55" lcd/hdtv and have to constantly adjust volume especially between commercials and programs. Can bearly hear the program turn it up and it blasts you out of your seat at commercial time. Had cable company out and it is definitely not the cable. Also have a problem with TV constantly shutting on & off. Does anyone have a solution???
Jan 14, 2011 | Vizio 42 in. LCD TV
I turn my volume completely up but can bearly hear anything and the green volume indicatoer bearly moves even though it is at the top. How do I get move volume.
The speakers have a volume control and your operating system has volume control. Check both.
If you still have a problem some music and video players also have their own volume controls so look for them.
Aug 18, 2010 | Computers & Internet
Bose Sounddock Volume Control Problems
Well, there really was nothing to it.
I let it dry out for the rest of the day and it went back to normal, thankfully.
:) Juliyana.
Jul 19, 2008 | Bose SoundDock Digital Music System for...
97 Jeep Grand Cherokee Limited Stereo problem
If you still have audio but unable to turn the volume, there are 02 possible problem:
- the volume control is defected will not respond ( electronic volume control; need logic low/high to activate the audio )
- the front control PCB is broken ( can be fixed if there is a small cracked )
If no audio at all then most likely audio output IC defected
Dec 19, 2007 | Cherokee (REF) AM/FM Stereo with CD Player...
Sony DAV-IS10 System Logo
252 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
