Question about Samsung Yepp YH-999 MP3 Player
Recovery mode for hdd damage - Samsung Yepp YH-999 MP3 Player
    President:
  • 803 Answers
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the Samsung's website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Oct 05, 2009
HP Desktop Error 0xE0EF0003 resolve this desktop error find out
no PC stated. wow1.
no OS stated, windows xp?
nor when you see the error.? exactly when
does windows run at all?
my wild guess.
you are attempting HP recovery mode.
1: HP disk set?
2: HP F11 magic recovery mode.
3: using recovery disks you made say 10 years ago>?
4:? or online hackers disks? or ? (endless examples here) ?
and the HDD is bad, and then shows that error.
right?
if trying to recover, step 1 is you testing the HDD first.
if bad recovery in impossible.
we boot to a linux DVD or USB stick
then run disk test first
as see here.
http://www.pcdied.com/linux.html
the error can also mean the recovery media is bad, or dirty or even scratched if CDs.
here i will now show the HP official page on this error
Recovery Manager could not restore your computer using the factory image. Please contact HP Support. Error Code: 0xe0ef0003.
This error can be due to several causes:
  • Corrupted image in HP recovery partition.
  • Damaged DVDs or corrupted image on the HP Quick Restore kit.
  • Failing memory module.
Mar 26, 2018 | HP Computers & Internet
Boot up problem
Dear sir/madam,
Please try these following steps.
1.) First You Need to Check if the HDD is Working Properly Or Not, So First Turn off Your Computer Completely and U Have to Tun it Back On.
Now As Soon as U Turn it On(Before the Compaq Screen Disappears, Keep Tapping the F10 Key Immediately To Go to BIOS.
Now In Your BIOS Go to The Tools Option and Execute the HDD Self test, Both Short and Long
[If the Test Fails Call Compaq Support @ 1-800-HPINVENT For Replacement]
[If The Test Says No IDE Device Found - U Must Try to Reseat the HDD]
[To Reseat the HDD - Turn U R NB Upside down and U Will Find a Comparment That Has the Symbol of Stack of Discs or Cds, Just Unscrew the Compart Ment and Pull the HDD Out, Then Put if Back it And Screw it Back]
Dont Worry - The Steps I Quote Here, Are Compaqs Prescibed Steps and It Will Not Void U R Warranty, If Fact If U Call Technical Support, They Will Advise U to Do the Same thing!!!!
If Both the Tests Pass then The HDD is Fine(90% It Should Not Be the Problm)
2.) Again Turn Your Computer Off and Turn it Back On and Before the Compaq Screen Disappears, Tap the F11 Key Which Bring Up the Built in Recovery Partion Menu.
From then On It is All Menu Driven
Note : Select Destructive Recovery If U Don't Have Any Importat Data in U R HDD
Else Select Non Destructive Recovery
For more information Contact:
www.hp.com/support
Good luck
Thanks
"Don't Forget to rate the solution"
Jun 26, 2008 | Compaq Evo N110 Notebook
I attach a 320gb samsung hdd with my asrock p4i65g motherboard but it show 320gb in bios mode and it show only 128gb in windows mode. how can i use 320gb hdd full space in windows mode?please help.
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Mar 17, 2011 | Asrock P4i65G Motherboard
My external hard drive was damaged i wont recovery from hard drive.
Depending on the severity of the damage you have a couple of options.
1) Put the HDD inside a airtight bag and place in a freezer for at least 4 hours. Remove the HDD from freezer and see if it works. If it does start to work you will have a limited amount of time to recover the data.
2) Pay Data recovery company to recover the data
http://www.ontrackdatarecovery.com/
Mar 06, 2011 | Transcend 160Gb StoreJet 25 Unveils Rugged...
My ps3 is working perfectly with firmware 3.40 .I started to update firmware 3.41 on thursday 5/8/10 Then i had a problem with my ps3. At first the ps3 downloaded data successfully then it started to...
This is a problem occurring in all the play station 3 consoles....... this is mainly because of some error in board .....as a result it leads to the damage of ur PS3 ....................try to update your system ..........
if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
Toshiba a15 s127 laptop message "missing operating system". Tried to reboot using recovery cd. Began okay at first, but then got message "Disk (E) Cannot format primary DOS partition-Bad system area" Does...
You either have bad sectors on your HDD or the recovery CD is scratched. If your recovery CD is clean and not damaged then a new HDD should resolve your problem.
Hope this helps,
www.PuterCare.com
Jul 06, 2010 | Toshiba Satellite A15-S127 Notebook
On recovery I get 2 messages. The first is
I am assuming you are recovering from a HDD partition and not form a CD.
This means you have serious HDD either physical damage to the HDD (aka you dropped the laptop while it was turned on) or psychical damage to the HDD (like windows did a messy thing while writing files to the HDD).
The fact is that you will not be able to recover from the files you have now, no matter how many times you try. The files are damaged.
Try contacting ACER and ask them for the recovery CDs (pe sure to have the laptop near you as they will ask for serial number, model number etc.
Best from here and good luck !
Dec 01, 2009 | Acer Aspire 3000 Notebook
Acer asire 5920 wont boot up cant get to windows to type anything in just a black screen asking for password or harddisk password. have acer aspire 5920 system disk it works asks for recovery disk 2 runs a...
For the psswords i can recomend to reset them from BIOS but to do that you must first know them. The problem with recovery disks is solvable if you boot from an XP disc and format the C: partition in NTFS file sistem and when it starts copying files to install the windows stop the installation ( F3 or press the power button for more than 4 seconds.. don't worry you will not sustain disk damage... done it myself with the same notebook for a dozen times ) After formatting the partition C: try recovery again and it will work.
NOTE: for the formatting of the partition you must set the HDD mode from AHCI to ATA witch permits the XP setup utility to "see" the HDD. If it is set in AHCI mode the setup utility for windows XP will not detect youre HDD
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Retrieving data from a damaged HDD
Download a free demo of Get Data Back for NTFS from http://www.runtime.org/data-recovery-downloads.htm it does the job right. I'm not sure of it's limmitations tho but if you'll need to have it work like it should use this info: Name:Pascal MEUNIER
Serial:DXCMFWHUNPIDTU
May 20, 2009 | Computers & Internet
Archos 605 wifi recovery code 107
Carbon Adsorption Solvent Recovery Systems
Oct 21, 2008 | Archos 605 WiFi Digital Media Player
Samsung Yepp YH-999 MP3 Player Logo
308 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
