Question about Apple Televison & Video
HOW DO YOU PUT YOUR SCERNE BACK TO NOMELE WHEN ITS TUNER UPSIDE DOWN?
    Sergeant:
  • 316 Answers
Turn it right side up!
Posted on Oct 04, 2009
Samsung Tv flipped upside down
Most Projector tvs usually have a mode for hanging them from the ceiling, as well as a shelf top.
Go to menu, settings, and then ceiling.
This option will convert the picture to project upside down.
Mar 19, 2014 | Samsung Televison & Video
LC-37SH12U picture is upside down
Its somewhat common for this to happen and generally its an easy fix but since your set doesn't have the flip picture option your going to need to get into the service mode to fix this...below are the steps on how to get into the service menu on a Sharp TV...once your in there you need to look for either mirror image or H invert, and change that setting from on to off or off to on depending on what setting you have.
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
Nov 06, 2017 | Televison & Video
Sensor not detecting water level magnet
Hi. This can be either the sencor needs replacing or the sencor float in the water tank is upside down. It may have come out at some stage and it was put back upside down. Dazza
Sep 18, 2011 | Gaggia Titanium Espresso Machine
My machine was working fine until i rewond my bobbin put back in machine started to sew seem to work fine i checked stich and it didnt have any thread in fabric
Check your manual. Make sure the bobbin is not in upside down. Most bobbins must be put in with the thread pulling from one side or the other. If you put it in upside down.... strange things happen.
Feb 05, 2011 | Euro-Pro Shark 60 - 384
I can't get the CD to eject.... in fact, I can't get the unit to acknowledge there is even a CD/mp3 option... IT just flips back and forth between tuner and aux. It was cold last night when I put a Cd in...
When you remove the faceplate you will find a small little black hole in the deck.Insert an opened paperclip to over ride the eject and make it come out.Please let me know if this helps
Jan 19, 2011 | Clarion CZ200 Car CD USB MP3 Player
TV goes blank (no pic or sound) when it gets warm. We put a fan blowing on the back and it stays on longer. Seems like a thermal issue. Got help?
Heat it shutting down ur Tuner board.That the board where,the tv broscasting signal go into it.It the major CPU processor have a shorting in it grounding leg,not taken in much thermal heat,more than a certain degree now,that why it shutting down.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.Or tries do some modifation to ur back cover,might work or allow the Tuner board take it in more thermal heat.Take a drill,drilling bunches holes like a square box 4"x 4 by the Tuner board biggest IC should work,if possible have more ventnalation where the tv sit at.
Jul 23, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I made the screen go upside down how do I change it back
okay 1st of all you need to take it off its mount if you havent done so yet or if you never did, you need to connect it to its power cord, press power put it upside down focusing it first of corse, press menu, setup/ installation whatever your projector calls it, projection,and select the correct one, when it has gone back to normall, put unit correct way up and enjoy.
Jan 21, 2010 | Office Equipment & Supplies
In my old Rca The chanels don change I want input in chanel 91-92
this sounds like a cold solder joint problem.. around the tuner, you need to unplug the tv and take the back off the set .remove chassis and turn it upside down ... take a magnifing glass and ckeck the curcuit board for broken or dull solder joints the resolder them.... this should solve your problem good luck
Dec 23, 2009 | RCA Televison & Video
Why is everything upside down on my telescope
The prism has been put in upside down.. Is it new?? I'd get it straight back to the shop for replacement..
Oct 15, 2009 | Tasco Galaxsee® 46-114500 (500 x 114mm)...
Televison & Video Logo
42 people viewed this question
Top Apple Televison & Video Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
Are you an Apple Televison and Video Expert? Answer questions, earn points and help others
