Question about Refrigerators
Side by side refrigerator leaks water from left front
Side by side refrigerator leaks water from left side front. It happens every so often, sometimes large amounts of water. The bottom of frezer compartment has a layer of ice on it. What can I do? Want to lay a new wood floor and can't until fixed. Thanks for any suggestions.
    President:
  • 1,304 Answers
Your defrost drain is clogged,
on the freezer, side take off the back wall
look at the bottom under the coil
you should see hole,,,, defrsot drain
whats happening with that clogged all the water from defrost runs right out the door
Posted on Oct 04, 2009
My Crosley CS23B5 is leaking water out the front left (freezer side) sometimes lately. Why is it doing this now?
door is not shutting correctly, look for a bad door gasket or the door iasn;t sitting square in the fridge
Aug 10, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Puddle of water on floor in front of side-by-side fridge. Fridge and freezer are cold. Drain pan is dry.
Lets make sure it is not something simple like a leaking water line behind the front kick plate. With that answered click here=> Leaking Refrigerators Just What may Be Happening Much more on this page=> Leaking Refrigerators! If you have questions please ask, Thanks Sea Breeze
Sep 23, 2011 | Whirlpool Refrigerators
Water leaking in front of the refrigerator
Lets make sure it is not something simple like a leaking water line behind the front kick plate. With thatanswered click here=> Leaking Refrigerators Just What may Be Happening Much more on this page=> Leaking Refrigerators! If you have questions please ask, Thanks Sea Breeze
Sep 23, 2011 | Maytag MZD2766GES Side by Side...
Kenmore side by side model 106.5xx. The ice bucket has ice but the dispenser on the door will not release the ice. I hear a click but nothing happens. I removed all of the ice from the bucket and the...
The freezer part is working but the refrigerator part is leaking water from the left side upper corner .there is like a vent from, where the water is leaking and the refrigerator side is not cooling any hint or advice will be appreciated thanks
Sep 19, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My matag model # mzd2766ge side by side has been leaking water on the floor. This happens only sometimes but by the time we notice its a big puddle on the floor under my cabinets. is something blocked up...
if it has ice/water in the unit,check the hoses going from the supply line at the inlet valve on the refrigerator rear section,if theres a hole in the tube,when the ice maker calls for water to fill the ice trays it will leak out this pin hole during the time the water supply valve is open and then shut off when the valve closes due to no pressure on the line then,thats probably the reason the puddles not always there
May 13, 2011 | Maytag MZD2766GES Side by Side...
Water on the floor on the left side of the refigerator
possible water line couplin leak located under left front of refrig behind grill or cracked line.
Mar 01, 2010 | Kenmore 53642 / 53644 Side by Side...
Maytag MFI2569VEB1 french door refrigerator has started leaking water from underneath. Seems to be coming from the left (facing) side, near the front. I checked water connection in back and in the left...
I will look for your service manual and tell you that first it's most likely a blockage in the defrost condensate line. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan,
water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage.
Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Dec 17, 2009 | Refrigerators
Water leaks out the left front. Water seems to pool and freeze in the bottom of the freezer. The leak is not alot but it never stops. Have checked for level have disconected the water and ice maker. Still...
You have a plugged up defrost drain. There should be a drain hole way in back of the freezer, at the bottom. (it should be behind the panel at the back of the freezer compartment) Use a turkey baster with warm water to flush it out until water runs out the hole into the defrost drain pan under the refrigerator.
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Leaks water
You likely have a plugged drain inside the bottom of the freezer. You may need a hair dryer to thaw it out, then clear it with a stiff wire. Otherwise your drain pan below may be cracked. Hope this helps!
Jan 19, 2009 | Whirlpool GD5SHAX Side by Side...
Kenmore Trio water leak on front left side
We have the same problem for the second time in 2.5 years.
Six months (Dec 2005) after we bought the refrigerator, water was leaking from the door. Sears repair arrived and informed us it was the water tank leaking. Said it wa a known problem and was replaced at no charge (of course, we were also still under warranty - six (6) months out) --- FAST FORWARD 30 MONTHS (May 2008) --- SAME SYMPTOMS SAME DIAGNOSIS only NOW Sears wants to charge me $155 to fix the problem.
I'm gonna be calling and complaining about that!!!!!
Open your left door and look at the flat face under the bottom shelf (you'll see representative water drops). The water tank is behind this panel.
May 25, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
