Question about Jensen 143307 Remote Control
Ascent Television I need of being un-locked
Hello, I was wondering if anyone knows how to unlock a remote in order to use the television. I have an ascent and dvd combo, and all of a sudden it went to a black screen with a red key on the bottom left corner. I am assuming it is locked.... what do i do?? Even if i unplug the television or attempt to push all buttons it doesn't unlock or do anything.
  • junY May 11, 2010
    Hello, I was wondering if anyone knows how to unlock a remote in order to use the television. I have a Zenith TV Modle SE 5221W. I tried to programm it with remote control but now I am assuming it is locked.... what do i do?? Even if i unplug the television or attempt to push all buttons it doesn't unlock or do anything.
Ok i want to know if you re stupid
Posted on Dec 26, 2007
Hard reset
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Jun 08, 2013 | Akai CTD-1390 TV
Television "locked"
Hello can you please post the brand and model of the television so we can find unlocking instructions.
Jun 18, 2008 | Televison & Video
Tip
Mitsubishi lock code
Mitsubishi Television asking for an unlock code.
Well you locked the set and forgot the code, or someone has locked the code before you got the set. One other scenario is that the code was entered by someone accidentally. Please note: If your parents have locked the television you should not be unlocking something that your parents have blocked. So don’t use these instructions to unlock a television that your parents have locked.
You must have the original Mitsubishi remote control to perform this operation on the set. Look on the remote for a button that is labeled QV (Quick View), if you have this button on the remote then we can press on. Go to the selected channel or input that is asking for the unlock code. When it asks for the code, press the QV button: Holding it down press the number 9 and release. This will unlock the set for this instance. To remove the code I suggest that you go through the setup menu and find the code lock and when it asks for the code use the QV+9 trick again to turn it off from the main menu.
If you do not have the original Mitsubishi remote you will not be able to try this trick. You will have to order a replacement remote from 1-800-REMOTES or www.remotes.com.
Once you have the replacement remote you can unlock the television and be back on your way.
I hope that this helps you with your television lock issues and as always, Thank you for using FixYa.
asnowman
on Mar 22, 2010 | Televison & Video
My akai tv is locked,don't know the code
Instructions
Sep 13, 2012 | Jensen Q2749J 27" TV
Remote Central locking
There are many types of aftermarket modules, some doing a simple lock/unlock, others also activating horns, lights, alarms, etc.
So I'd suggest searching for "how to wire car locking module," then checking out the results (including many YouTube videos).
However, you'll probably install the unit inside the driver's door panel, because that door's exterior lock and interior lock button give orders to the locks in the other three doors.
Then, use a circuit tester to identify:
--one wire that is always hot, whether the engine is on or off. This will usually be colored. This wire should be connected (use a crimp-on connector) to the power supply for your aftermarket locking module.
--a black (usually) ground wire, that should be connected to the ground wire on the module.
--one or more trigger wires running from the lock switch on the door. There are different types of trigger setups and different ways to connect them, so there may be some trial and error involved. When you've got everything hooked up, though, make sure the "lock" button on your remote makes the doors lock (and vice versa for the unlock button). If the commands are reversed, simply swap the control connections.
--if your new module also has the capability of making your horn sound and your headlights and taillights flash ... well have fun. You'll have to figure out how to hook up the wiring on the module to the headlight and taillight circuits, which won't be obvious or easy. Personally, I'd skip that part and be happy with the remote lock/unlock.
Jan 30, 2018 | 2001 Toyota Corolla Ascent
Need tv code, tv is locked
5
Also note that forgotten the passcode of your Mitsubishi TV. You can make it alive without knowing the passcode. Please follow
V_Chip lock bypassing prodedure is as follows
You can view your locked TV, cancel the lock, or enter the V_chip lock menus.
This is done by pressing the number "9" and "QV" buttons on the remote TV control at the same time, when your passcode is requested. This process temporarily unlocks the TV.
When entering the V_Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
I hope this will help to solve the problem...
Aug 20, 2011 | Mitsubishi VS-60703 60" Rear Projection...
Un lock child Lock.
HAL DIE EPROME YT SIT AN TV VIR EEN SEC EN SIT EPROM TRIG EN SIT TV AN
Jun 13, 2008 | Akira EPM-420A 42 in. Plasma Television
Accidentally locked out of my TV
Unfortunately with this model of Insignia you MUST have the remote that comes with that model number in order to unlock it. Other Insignia remotes won't work. So I have ordered another remote from an online company. Hopefully that will work. I'll probably have to call Insignia to have them walk me through it once the remote arrives.
May 24, 2008 | Insignia LCDTV26 26 in. Television
Television Locked.
My Durabrand DBTV1020 is locked. I dont have a manual or remote. HHow do I unlock it?
May 19, 2008 | Televison & Video
Polaroid FLM-1507 locked
My son locked my FLM-1507. I do not have the remote to unlock it. I also need the code to unlock my FLM-1507.
duanehatl@yahoo.com
Sep 16, 2007 | Polaroid FLM-2011 Television
Jensen 143307 Remote Control Logo
118 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
