Question about Video Cameras
Reset a camcorder
I have a grdf430u that the iris sticks shut on. i usually open it up and unstick it, close it up and it works fine. This last time it does not power up at all. Is there a way to "reset" the camcorder? Could it be the lithium battery inside of it is dead?
Mike
  • xminbr Dec 24, 2007
    i will try changing it. its a cr2032. not lithium. i would guess that is just to hold the memory settings anyway. i have tried a couple of different main batteries and a couple of different wall chargers. I have a grdf550 that the tape mechanism died in and i wanted to take the lens assembly, main board, and button panel to upgrade the 430. the units use the same case with some hardware diffs. sd card and usb port, lens assembly are the main ones. both units use same plugs for components on main board.
  • 790 Answers
Ya lithium battery doesn't cost u much , u just give a try once cahanging it and later let me know ...
GUD LUCK!!
Posted on Dec 24, 2007
    Master:
    Sergeant:
  • 482 Answers
I would start with the batteries. I dont belive threre is a reset to it.
My problem is im trying to record and i have the camera switched to tape and have it turned on to camera and it records sound but will not record picture, but will play back other tapes on the screen ok.I...
If the iris is opening to let light in, that light is not being changed to a picture signal or that picture signal is not
going into the camera circuits, What you see in the viewfinder is what is being recorded, Make sure that no cables have been left plugged in to the camera and turn the power on and off several times, I have seen the iris stick when cameras were not used for a while. The iris is inside or behind the lens and closes completely when you turn the camera off, If it is stuck, SOMETIMES it will open with repeated tries of turning it off and on or even removing the battery and putting it back in. And maybe it is just the vibration of opening and closing the battery compartment door or the slight vibrations of pushing the power button repeatedly. If it sticks once, it will stick again. This is not a repair, just a way to get those one time pictures' before.
Jan 08, 2018 | Canon ZR50MC Mini DV Digital Camcorder
GR-D33U camcorder..... No display on LCD or viewfinder. Message states that lens cap is on but it is not. Tried all settings in menu....no luck! Any suggestions?
Zoom the camcorder as far as it will go and shine a flashlight into the lens assy. Inside the lens assy there is an iris that works pretty much like our eyes (closes when it is too bright and opens up when it is darker). If all you see is black when you are shining the light into the lens, your iris is stuck closed (like having your eyes shut). If your iris appears to be open and functioning properly, then you likely have an issue with your CCD assy. The CCD assy is the what lets your lens talk to your main PCB.
Sometimes by zooming in all the way and shining a light into the lens, the camcorder will "unstick" itself. You will most likely need to have it repaired by an experienced technician.
Hope this has helped you.
www.austintelstarservices.com
Sep 09, 2010 | JVC GR-D370 Mini DV Digital Camcorder
I have a JVC GR-DF450U camcorder. The playback works fine but the is no display when recording.
If you mean no picture during camera mode(that is all black screen), Something must be done to your camera. Iris motor unit fails to open causes the problem of no picture since iris is close. Solution, clean iris curtain, needs skill. I suggest have it checked by qualified person. Hope it helps, Good luck
Mar 01, 2010 | JVC Video Cameras
My dcr-hc21 handycam only pics up picture when you are pointed directly at light, it hasnt always done this. its as though the lens is closed, but its opened...anything i can do?
Most likely, your problem is seized IRIS assembly. Usually, repair is simple- Iris assembly requires cleaning. No adjustments are necessary after repair.
Dec 22, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Hello have a low light setting on my AG-DVX100BP that wont allow the video to show?
Hit the iris button on the side of the camera, then use the dial to dial the iris into an open position and let more light in. Know that the higher the number, the less light coming in, so 16 is just below closed iris, 2.8 is just before completely open iris. The iris is like the pupil of your eye. You should always be in manual iris to control the iris with the iris dial, keeping the video between 4.0 and 6 usually gives you the best exposure (not too hot or too low light.)
You also may have a neutral density filter on. You should only apply this switch if there is too much sunlight. Use nd 1/8th for moderate sunlight, nd 1/64th for bright sunlight. Then adjust the iris with the dial again to get the best picture exposure.
Jun 08, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
2000 Ford Excursion diesel when shut off interior and running board lights stay lit for long period of time or won't go out at all which in turn causes the cars battery to go dead.
You have a door ajar switch sticking in one of the doors. Start with the drivers door,open door and spray a liberal amount of WD40 into the latch on the side of the door. Then open and close the doors firmly several times. This usually unsticks them.
May 12, 2009 | 2000 Ford Excursion
My lcd and view finder are unable to show subject
The problem you are having is called a "stuck iris" Inside the lens are two thin plastic sheets that slide over one another that limit the amount of light that comes into the lens. In some Sony camcorders, the motor or "actuator" that drives the iris, or moves the two sheets which are the iris opened and closed. The actuators sometimes leak oil onto the plastic sheets causing them to stick, so the light coming into the lens is stuck at one level. Some technicians will recommend lens replacement (expensive) but many times the iris assembly can be removed from the lens and cleaned. Try to find a service shop that will clean the iris rather than replacing the lens.
Nov 11, 2008 | Sony Handycam CCD-TRV98 Camcorder
Camcorder wont show images
This sounds like the iris is stuck almost closed. You can try gently tapping the side to attempt to release the iris. If that fils to resolve the problem, the unit should be brought to a servicer to rebuild the optical block.
Dan
Sep 11, 2008 | Canon ZR830 Mini DV Digital Camcorder
No image on lcd or view finder help
i think the iris of your camera is not opening....it need to clean the iris by the lighter fluid cause of some grease that sticking in the iris...don't attempt to do this is you are not a technician...
May 05, 2007 | Panasonic NV-DS60 Mini DV Digital...
Records sound but no picture
there are two possible problem of your camera...one check the iris of the camera if it is opening,you will see it went you look inside the lens when you turn on camera mode....and if you see that the iris is opening...the second may be the ccd image sensor......if that is the problem you have no choice but to go the sony service for replacing the ccd image sensor...
Sep 03, 2006 | Sony Handycam CCD-TRV37 Camcorder
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
Video Cameras Logo
65 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
