Question about EliteGroup ECS PT800CE-A Socket478/PT800CE/DDR400/A&L/ATX Motherboard (MOTEC13)
ECS PT800CE-A 3.4 P4 HT CPU and DDR400 (PC3200) problems
I bought this board new a couple of years ago. My main computer died so I thought I would use this board and build a new one.
At this point I have installed and configured the motherboard, installed the 3.4 HT CPU, installed a floppy drive, installed an FSP 700 Watt power supply, installed 2 Gig of Kingston DDR400 memory and installed an ATI Radeon 9600XT AGP video card.
I used Microsoft Memory Tester to check the memory. I seem to always get ERAND errors. I took 1 stick of memory out and tested the remaining 1 Gig stick. I still get ERAND memory errors. I took out the last stick of memory and replaced it with the first stick I took out. Ran the memory test again and found that I still get ERAND errors.
I then gave up on DDR400 and tried DDR333, also Kingston. I put 1 stick in (512MB) and ran the memory test again. I only let it run for 3 passes and no memory errors where reported. I then removed that stick of memory and put the 2nd stick in. I ran the memory test again for 3 passes and no errors were reported. Great, on to the next step.
I then placed both sticks of DDR333 memory in (1Gig total) and ran the memory test. I am now back at the ERAND errors. Strange that each stick passed 3 passes (11 tests per pass) each but produce ERAND errors when 2 sticks are placed in.
The DDR400 ERAND errors where reported for each pass done. It did not matter, 1 stick at time or 2 sticks together. The DDR333 stick passed 3 passes (11 tests per pass) each but produce ERAND errors when 2 are used together.
Does anyone have this motherboard running with DDR400 memory? If so can you please provide me the make and model number.
Thanks for any help,
Charles
  • Charles E Finkenbiner Oct 04, 2009
    The CPU is not overclocked at all. I too do not know what an ERAND error is. It is test number 10 out of 11. I have tried every setting in the BIOS to tweak the DRAM timing. I loaded the Default BIOS settings, made no changes, but I still get these errors. As far as I can tell from BIOS 'PC Health' display the voltages are within specs.
    Thanks,
    Charles
    Guru:
  • 597 Answers
I seem to be unable to find any information about what an ERAND error even is. No one is really identifying it on the net. One thing you may try though is to find out if the bios settings are maybe causing this. Is the system overclocked at all? Are the voltages correct? Maybe try resetting Bios to default settings and trying again.
Posted on Oct 04, 2009
  • obwhon Oct 05, 2009
    I checked the web site. You've done all I can think of. the DDR 400 is the correct ram for the mother board. One other suggestion is to remove the ram and make sure the ram slots are cleaned out. Blow some compressed air down into the sockets.
I put the battery on charge for the first time 26 hours ago and it still isn't charged. What do I do now?I haven't even activated it yet.
I bought one a couple of years ago and it would not take a charge and since it was new I took it back. They commented that sometimes the batteries die in transit.
Jan 09, 2016 | Cell Phones
Tip
I have the same problem with a Canon Powershot s20. Bought approx 5 years ago...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Jan 28, 2008 | Samsung Digimax D53 Digital Camera
2000 Buick Regal... All the lights, every single 1, in the dashboard started flashing & the car went dead. Will not start back up unless the head lights or emergency flashers are on but will die again...
I had this same problem a couple of years ago, $2000 dollars later my ex in-law spend at the dealer and the problem still existed, (they replaced the ignition switch, the entire fuse block assembly, battery, alternator and a couple of other things ). I bought a new turn signal switch for under $100 and never had the problem since...
Jul 29, 2013 | Cars & Trucks
Hi. i bought my acer aspire 5583 3 years ago...now it suddenly can not be turned on... last 2 weeks i still can play it..but one week later when i came back from holiday...i found out sth wrong with my...
This is just a suggestion ... try removing the battery and turning the computer on with only the mains power lead attached.
Sometimes, as the battery dies, it does silly things with the computer.
If it works, order a new battery.
Hope this helps,
CJ
Jul 02, 2010 | Computers & Internet
My HJ720IT pedometer screen is blank. I thought the battery had died but got a new battery and it still won't work.
Mine has same problem. Died a week ago. Put in new battery and it worked for a week. Now it is dead again.
Dec 23, 2009 | Omron Hj 720ITC Advanced Pocket Pedometer
I was given this washer as a back up,the lady told me it is 3 years old.A couple days ago she said she was washing and the fill station would not stop filling.I thought it was from hard water build up.I...
Yes if you have removed the water lines from the rear part of your washer and there was buld up there you would need a new water valve.would not risk the chance of a flood hope i helped:)
May 15, 2009 | Washing Machines
Rechargable batteries drain as soon as they are put in the camera
Your circuit board has developed a short. There is only one way to fix it, replace the main circuit board. Buy an A530 camera with a cracked LCD online from someone, to fix it.
Nov 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
MAH3000AWW
Replace both the main control board and the wax motor. This sounds like a computer chip malfunction
As far as the squeak, make sure it is not the bearing located at the back of the tub under the large pulley.
Jan 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Computers & Internet Logo
143 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
