Question about NetGear FA311 - Network adapter - PCI - EN, Fast EN - 10Base-T, 100Base-TX (FA311SE) Network Adapter
Netgear fa311 fast enthernet adapter
Hi just rebooted my pc and the adapter is not working naw and do not have a driver disk it was working befor i did this. thanks
  • 154 Answers
If you've lost the driver disk, use the link below to download the driver of your network adapter.
http://kb.netgear.com/app/products/model/a_id/2357
hope it will help you
Posted on Oct 04, 2009
    President:
  • 1,884 Answers
Go to
http://download.cnet.com/NETGEAR-FA311-Fast-Ethernet-Adapter/3000-2112_4-62926.html
to download the driver for this adapter and burn a CD for future use.
NETGEAR FA311/312 PCI Adapter issue. I'm using it in a Windows Vista environment, and was working just fine up until recently, and now Vista does not even recognize a cable is plugged in. In regards...
Hi Iron - Included with the driver disk available from Netgear's website is a diagnostic program that will pinpoint your problem.
The file is called diag.exe - double click it and it will run tests on the adapter.
Also, are you sure you haven't accidentally used older drivers? Vista requires driver disk 6.1 available HERE.
Hope that helps sort you out.
Regards,
Mikeywaf
May 12, 2011 | NETGEAR FA311/312 PCI Adapter
My gateway inside my desktop keeps disconnecting from my ethernet can you tell me what I need to do I have a Sony VAIO VGC 310 with window 7 upgrade
This computer's original OS was Windows XP. Check with the Intel Website (www.Intel.com) to see if there is an updated driver for the Ethernet Card and Chipset for the Intel Pro/100 Ethernet Driver for Windows 7. Intel has a utility you can run (follow the instructions) which will detect all your Intel Chipset hardware and provide you with updated driver information. If there is no Windows 7 driver, try using these steps to correct the issue: 1) download the most current ethernet driver from Intel and save to a folder. 2) Once the download is complete, locate the file and right click on it, click on "Properties" 3) select the Compatibility tab and set the options to run the program in Compatibility mode for Windows XP Service Pack 2. 4) A little farther down in the windows, check the box that says "Run as Administrator" 5) apply the settings and close the properties box. 6) double click the the driver file to activate its install. Follow directions and see if this helps your issue. You may need to remove the originial driver files first. To do this, Go to the Device Manager in the control panel from the start menu, Find your Ethernet adapter in the Network Adapters hardware list, right click and select "uninstall" and check the box to remove the driver files, then click okay - then reboot the machine, the run the new driver file you downloaded from Intel in compatibility mode per my previous instructions. If this doesn't solve your issue, I recommend installing a new network card that is compatible with Windows 7. Its an easy install and shouldn't cost you very much . . . less that $25.00 and should take only about 15 minutes to install. Here is a link to Netgear and their Windows 7 compatible hardware Ethernet card for about $19.00. http://www.netgear.com/Products/Adapters/WiredAdapters/FA311.aspx
Your local Wal-Mart or Target will probably have these and other brands in stock.
Hope this helps FixYa! If you find this information helpful, please leave feedback.
Apr 06, 2010 | Gateway GT4016 Desktop PC
Problems with WiFi netgear WNDA3100
the drivers should be installed in windows 7 by default, their so called "smart wizard" has some compatibility issues with windows 7, I get it to load up and it will shut down or glitch out. What I did was uninstall the downloaded driver and use the default windows drivers, flipped the switch off to my built in G wifi adapter and the netgear automatically kicked in and took over as the default wireless adapter.
Nov 06, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
No conection to internet by local network
hi! there,
if you have *********** board installer,install and the wizard will find your ethernet driver if this buit in ethernet,but if you have an external pci enthernet device go to device manager,left click and click the properties of fast ethernet pci device,try to update your driver on website.device maneger can find on control panel under
system,click hardware,click network adapter,click properties and click on drivers and update your driver.have a nice day.
Apr 15, 2009 | Computers & Internet
Desktop restarts every few minutes
First I would try reinstalling the driver for the FA120. DOwnload it here: http://kbserver.netgear.com/release_notes/d100006.asp
If you still have the same problem, they have a nice page here which gives you some good steps to go thru: http://kbserver.netgear.com/kb_Web_files/N101250.asp
It *might* be spyware or virus activity... rebooting like that. I would suggest updating your virus and spyware definitions and scanning your computer also.
Jan 20, 2009 | NetGear FA120 2.0 Fast Ethernet Network...
I neen a web pass phase #
Hi, perhaps this tip will help? Go to Part 1 only, 'Retrieving a lost network key'. The network key is the same as the passphrase. If you need help with logging in to your router, please post again.
I hope this will help you.
Jan 13, 2009 | NetGear - FA311 - 10/100Mbps PCI Network...
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
Netgear has strong connection but it doesnt connect
I think you may that the "Drivers" & OR settings for this WiFi adapter are not working correctly. What ya need to do is Install the "Drivers" & "Software" from the Netgear CD that came with ya device and set it all up per your manual. Here are a couple of links to help below.. mobileoffice.about.com/od/findingusinghotspots/l/blwificonnectio.htm www.microsoft.com/windowsxp/using/networking/expert/bowman_02april08.mspx Basically, ya install the drivers & software reboot, insert ya USB WiFi into ya USB port, if it then asks for "Drives" point it to ya CD... when finished then you should be able to "See" ya Access point etc.. and connect.. setting any protocols you wish..
Aug 23, 2007 | NetGear MA111 802.11b Wireless Adapter
NetGear FA311 - Network adapter - PCI - EN, Fast EN - 10Base-T, 100Base-TX (FA311SE) Network Adapter Logo
148 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
