Question about Sony VAIO VGN-SZ230P/B Notebook
How to get at the hard drive on sony vaio laptop VGN-SZ230P, I tried to undo all screws on the underside and cant pry it open the under cover , seems caught , afraid to break it are there any screws under the round black glued cushion padsthat I should look for ? is it a 3.5 or 2.5" drive? so i cna order the new one I found specs saying its 3.5 but my friend sys it cant be its too big for a laptop? many thanks pierre
  • 52 Answers
Visit the how to guide at
http://www.laptoprepair101.com/laptop/2008/01/07/service-manuals-for-sony-vaio-laptops-notebooks/
and at
http://repair4laptop.org/disassembly_sony.html
they have easy instructions
good luck
Posted on Nov 05, 2009
  • 3,940 Answers
Pierre
Sony indicates that the hard drive is not a user replaceable device on that model, so it appears that disassembly of the chassis is required to remove the hard drive. Information can be found here: http://laptoprepair.ca/news/11294/2.html There are a series of disassembly photos at the bottom of the page (Best info I could find) The HDD will be 2.5 inch (3.5 in drives are desktop) You can find replacement drives here: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148310
Posted on Oct 04, 2009
  • 85 Answers
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I have a Sony Vaio VGN-SZ230P. I am having difficulty downloading the Fn drivers (such as the volume, screen brightness, etc.) I have went...
There is a specific set of driver you have to install for your computer, Vaio laptops use the ACPI fucnction to control hardware access like volume / brightness control etc
You need the ACPI driver installed for Fn key to work
Install Sony Notebook Control Driver for windows vista
Install Sony Utils.dll
Install Sony Shared Library
same for your sd card reader just reinstall the drivers
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNSZ230PB&LOC=3
sony only supports the factory shipped os drivers you will have to find the drivers for 7 elsewhere or reinstall your factory os
Jun 14, 2011 | Sony VAIO VGN-SZ230P/B Notebook
Hi, I need to replace my DVD-rom but I don't know how to remove it from my laptop. Please help me out. Thank you.
It is held in place with one screw that is located on the bottom of the laptop, near the center but closer to the dvd drive.
Aug 28, 2010 | Sony VAIO VGN-SZ230P/B Notebook
How to change hard drive on Sony VGN-N130G?
I need the model number printed on the front of your case, VGN-N130G does not exsist on the sony web support page. http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB
Usually there is a cover under your laptop that is marked.
Remove 1 or 2 screws and your harddrive should just slide out.
Jul 14, 2010 | Sony VAIO VGN-N130G/W Notebook
How do I remove the fan from the unit? Sony VGN-SZ230P HOw do I disassemble the unit to get access to the fan
visit
search for your model
they are extreemly easy to follow
Sep 16, 2009 | Sony VAIO VGN-SZ230P/B Notebook
Sony vaio vgn-TX750P how to open the case to swap the hard drive
here you go mate i found u this coz i know how much of a pain in the arse sony vaio's are :
http://laptoplogic.com/resources/detail.php?id=43
GOOD LUCK LADS!
Aug 08, 2009 | Computers & Internet
OPEN Sony VAIO VGN-T330FP TO CHANGE HDD
turn the laptop upside down ...remove a partial plastic cover attached by a screw on its edge ( there is a small sign showing the hard drive usually) after taking the cover of plastic away the hard disk is visible . pull it gently aside (sideway)
and replace it with the new one.
May 29, 2009 | Sony VAIO VGN-T350 Notebook
Laptop is a Sony Vaio VGN SZ230P. It started freezing up. Looked in Task Manager and SYSTEM was using 80% or more of CPU. Reformatted using the recovery partition and problem was still there. Reformatted,...
It could be a bad driver, have you checked Sony's site for an update, or looking a non-sony, later version of the driver for the device, perhaps just google SigmaTel [device name]?
Feb 03, 2009 | Sony VAIO VGN-SZ230P/B Notebook
Replacement of hard disk in Vaio VGN-A150
Well, it's not good news. Official word from Sony:
Knowledge Article C309925...
Can the notebook hard drive be upgraded or replaced
Hard drive upgrades in the notebook computer are not supported.
NOTES:
* Some notebook computer have instructions for warranty replacement of the hard drive by an end user.
* Although third-party upgrades may be available for some models, they are not supported.
* If the hard drive needs service, repair should be done by an authorized Sony service center.
* External hard drives may be attached if the appropriate connections are available.
This basically means complete disassembly of the laptop is required to get at the hard drive. Not that it can't be done. Just that it'll be a major pain in the .... you know.
There is no hidden key!
Jul 24, 2008 | Sony VAIO VGN-A150 Notebook
Sony VAIO VGN-SZ230P/B Notebook Logo
300 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
