Question about Logitech Cordless Mouse
I don't see how to open it, don't want to break it.
  • 85 Answers
To open the battery compartment, slide the cover off, it slides off away from the buttons. To open the inside...there is no reason to as there are no user serviceable parts inside!
Posted on Oct 04, 2009
I am locked out of garage. Liftmaster 1265 will not open.
Sounds like what you need acces too is inside the garage. If you don't have a pedestrian access door to your garage, or a window, or these are both locked, you are going to have to break something. Sorry to tell you that. Just pick the thing to break which is easiest to repair. Once inside, there is a mechanical release (usually a pull rope hanging from the opener main unit) that allows you to open the door manually. Then you can use the garage until you can address the problem. Good luck.
Oct 23, 2012 | liftmaster Chamberlain Garage Door Opener...
Don.t have break light
see the diagram and fix it. God bless you
tight any plug +connector and clean from corrosion , oxide +test the fuse and replace+test the bulb for open or bad contact, clean the contact from oxide, corrosion. etc.use the VOM
Oct 05, 2012 | Cars & Trucks
The safety thermostat switch keep breaking (opening) every 3 to 4 moths don't know why
The sure don't make things like they use to. The only thing I would think is that the drier is getting too hot or the switches are poorly made. Might check the exhaust duct or see if you can find a better quality limit switch.
Apr 04, 2012 | LG DLE5977 Stainless Steel Electric Dryer
When I was attaching the screen to a VESA arm, one of the nuts inside the unit came off and is floating in the unit. I need to get the back cover off to get the nut and re-attach it. How do I get the...
As it appears it seems that the back of the unit is held together by clamps. I wouldn't advise you to go ahead with the dis-assembly because you risk breaking the clamps. But if you must do it proceed with caution. Start prying open from the bottom screws toward the top of the unit. Use a plastic wedge to help the prying. It really comes down to finesse and experience. If you don't feel confident doing it don't do it as you might break it irreparable. The mount should be usable even mounted in 3 points.On the other hand the loose nut could cause some damage short circuiting the board. \
Good luckVlad
Feb 27, 2012 | Samsung B2230 LCD Monitor
How to break my security code.?,my phone is nokia 2700 classic.
Hello Anis,
If you want to break the phone security lock :
Switch off the phone.Remove the battery for 30 minutes. Reinsert the battery and switch on
the phone.Enter the default code 12345 or 00000.Your phone will be unlocked.
If you want to break the phone memory card security lock :
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
May 28, 2011 | Nokia Classic 2700 Cell Phone
Front and back speakers quit working but my subs still work. Is this a fuse problem?
Don't know,but I doubt each different speaker would be fused
Something NO ONE seems to understand IS
Look at an actual fuse
They are no more than a piece of wire
They don't do anything
They just sit there and wait for high current
flow,that causes them to get hot & melt,thus
breaking or opening the circuit they protect.
If a fuse ever opens or blows you DO NOT replace it
You find out why it blew,you have problems down steam
in the wiring.
Apr 27, 2011 | 2004 Nissan Sentra
Password break
hi to unlock your memory card you have to these steps:-
1. Insert card into your phone but don’t access it through phone. 2. Run FExplorer and Open the path C:\system. 3. You will find a file called mmcstore ,rename the file mmcstore.txt 4. Copy that file(mmcstore.txt) to your pc and open that file in notepad. 5. You will find your password in that file.
May 13, 2010 | Nokia N93 Cellular Phone
Problem opening up vacuum cleaner to get at power input from cabl
They're very robust you know, if its an upright, start with the screws at the bottem plate unless there's aa way of accessing the cable from the handle, on a cylinder just undo the hefty Philips screws, i don,t think you need a manual, just keep it all tidy and set out your parts on a nice best table cloth in order of removel, wish i was there with you Joe, good luck , the Yeti
May 20, 2009 | Vacuums
Changing Brake Pads
Well the first thing U need to do is clamp off your break line,{u only have to do this if it has abs}which that year.then you nee to break open the break bleeder vavle.Whants you have don this then you are raedy to unbolt the break housing and remove the breaks and replace.Put back togather and close the bleeder vavle and take the clamp off the break line.Now you are ready to bleed the breaks.The same way for all four.{if your car has disk breaks in the back}
Oct 17, 2008 | 2002 Chevrolet Impala
Logitech Cordless Mouse Logo
95 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
