Question about Bosch Freezers
What does the 'S' button mean on the Bosch economic freezer? does it need to be on?
My Bosch upright freezer motor runs and gets hot, but the appliance does not freeze inside. What could the trouble be??
I would suggest either the coolant has partially escaped and needs re-pressurising or the compressor is damaged. Both of these faults would result in the motor overheating and both would need the attention of a service engineer.
Dec 08, 2014 | Bosch 8.7 cu. ft. / 246 liter Upright...
Hi, I have a Bosch Logixx Fridge/Freezer (frost free), works fine apart from large build up of ice on floor of freezer which I constantly have to remove. Any ideas? Many thanks Peter
Hello
check that it defrost elements (heater elements) are working if they working then check if the sensor is working and if the door is sealing when its closed or if the drain is open.
Thanks
Jun 04, 2011 | Freezers
Does not get cold anymore. When I plug it, I can hear the motor running for about 10 sec and then I hear a clic and everything stops
thats the Compressor overheat relay kicking in sygnifying a faulty compressor meaning a systems engineer is needed to replace if economically viable..
Dec 22, 2009 | Freezers
We have a bosch economic no frost freezer which is several years old. Recently we noticed that although it was showing the correct temperature but the contents were not frozen. We ehave emptied the freezer...
The starter/overload relay may be bad or the compressor is overloading the relay. See how to test them here. How to check stuff> http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 30, 2009 | Freezers
Temp not going below zero
If that is 0 F it is probably the default temperture and is ok. Above 0 food detoriates quicker and below you get freezer burn faster.
If the controls are locked to that temperature it usually involves holding the button for 3 to 5 seconds to unlock and then adjust. (That is on modern frost free freezers in general)
May 04, 2009 | Bosch Freezers
The alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
Apr 01, 2009 | Bosch 9.1 cu. ft. / 258 liter Upright...
Bosch freezer
Condensor coil needs cleaning.
Aug 02, 2008 | Freezers
Freezers Logo
888 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
