Cleaning Problem "Unable to Clean, see chapter 4 in Troubleshooting" lost the guide, can anyone suggest a solution to fix this trouble... Thanks
Mix-it-up
  • 832 Answers
SOURCE: Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Posted on Mar 08, 2008
Mix-it-up
  • 832 Answers
SOURCE: Brother Model DCP-117C Printer -
you need a new ink absorber box which you can buy from a brother service dealer near your home (see brother homepage of your country). when done so open printer:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google translation german)
you have to rest the eeprom parameter, too
press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will switch to maintenance mode. press by help of arrow up and set : 8 - 0. press start bk-copy til PURGE 64xx appears. press the sequence of 2 -7 -6 -3 (arrow up and set). PURGE will reset to 0000. press 9 - 9 to leave maintenance.
Posted on Apr 23, 2008
unable to clean troubleshooting maintenance user guide
Posted on Jun 23, 2008
  • 742 Answers
SOURCE: "Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET
b. 0 then press SET
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET
b. 7 then press SET
a. 8 then press SET
b. 3 then press SET
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET
b. 1 then press SET (To reset unit)
a. 9 then press SET
b. 9 then press SET (To exit Maintenance mode)
Posted on Jul 11, 2009
komguy
  • 2306 Answers
SOURCE: unable to clean see troubleshooting and routine
Unable to clean means the ink absorber box is full. You will need a shop to replace the waste ink absorber box and then reset the waste counter in service mode.
Posted on Jan 29, 2010
"clean unable 46 " and see troubleshooting and routine maintenance chapter in users guide.
HI Gail,
Please watch this brother problem related video and solve your problem.
Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother DCP 165C Compact Color Inkjet...
Unable to clean see troubleshooting and routine maintenance chapter in user's guide
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Clean unable 46
Hi, check to see if there is any foreign object jamming the print mechanism, check all drive belts. If this doesn't show nup any problems, I'm afraid that you have a failure that will require dis-assembly and repair by a company who deals in these printers.
Apr 12, 2009 | Brother DCP 130C All-In-One InkJet Printer
Will not print
You have a major error, probally head stuffed error 41, to find out your error press menu starte and up 4 times, this may show error if not then input 82 set, error will display.
Post back if need more info
S.
Jan 14, 2008 | Brother MFC-5440CN All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Printer refuses to clean.
here is the link for the manual; http://www.brother-usa.com/Data/Documentation/Fax/User/MFC210CMFC420CNUGVersB.pdf Hope this helps :)
Sep 08, 2007 | Brother Multi-Function Center® MFC-215C...
12 people viewed this question
jasbo
jasbo
