NEED DRIVER TO INSTALL PRINTER - Office Equipment & Supplies
  • Kerry Degrand May 11, 2010
    what printer model and make??????
How do I hook a printer to my presario 700 laptop
Connect the printer to the laptop with the printer cable.
Then you need to install the printer driver on your laptop.
You need download the printer driver from the printer manufacturer's WEB site and then install this driver.
Dec 04, 2012 | Compaq Presario 700 470024-192 Notebook
Trying to install printer
You should have install the printer driver on your pc before paired them in the first time. This is to make sure your printer can work smoothly on your PC/OS. Otherwise your OS will run its standard driver ( sometime this standard driver will not work perfectly for your printer, especially for uncommon printer brands ).
So, again for best result you need to install its original driver ( it usually bundled on printer box while you bought).
regards
Sep 16, 2011 | Computers & Internet
Trying add Lexmark x1240 printer to my laptop it doesn't print. I received it from someone .who never used it
Is 'lexmark x 1240' show as printer icon? If no . The printer driver does not install properly.To install the driver properly follow the mentioned proces.
1.Insert installation disk in the cd rom.
2. click coustom install, then click driver. Install will be copntinuin. After a few time printer connection will want. In that time you need to on the printer. Then printer is automatically install .
thank you
Aug 17, 2010 | Lexmark X1240 All-In-One InkJet Printer
Does this printer need a CD ROM?
Yes you need to install driver if you don't have disk then download driver from below link.
Click here
Click on above link and select your os then download driver and install.
Then you can use your printer.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 12, 2010 | Canon i850 InkJet Photo Printer
How to download installer without the cd?
you can install printer with window basic driver but this printer is new so window do not have the default drier for this printer you need to install driver from internet and then install your printer, follow this step to install printer and download drivers,
1. click this link to download driver for your HP F4100 printer FROM HERE.
2 select your printer model.
3. select your operating system.
4. then download the HP deskjet full feature software and drivers.
5 when download complete run the setup file to install driver for your printer.
6 do not plug the usb cable to your computer until setup prompt you.
7 follow the onscreen instruction which is coming on setup page.
8 and your printer is install and ready to use.
Thank you for using fixya
Regards
Manish
Jun 09, 2010 | HP Deskjet F4100 All-In-One InkJet Printer
When i try to scan the printer says i have no connection it tells me to turn on the computer or install hp software. I am connected and I have scanned before
ur printer files are corrupted...reinstall the printer driver /softwares...or
uninstall ur printer driver / software and re-install
Dec 23, 2009 | HP PSC 2175 All-In-One InkJet Printer
I have lost the cd to install my printer Dell All-in-One 924
click here for downlaod driver
click on above link then downlaod driver and install.
Select your operating system then downlaod driver.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | Dell 924 All-in-One InkJet Printer
Need to install printer and can not locate install disk
Go to the website of the printer manufacturer. Click on DRIVER DOWNLOADS. Download the correct driver for the printer you want to install. Save the driver on your computer's desktop. In the Windows® control panel, click on the install drivers icon. Drag the downloaded driver into the HAVE DISK data field. Follow the instructions for installing a driver in Windows®.
Sep 27, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Need to install printer, can not find cd to install, printer has been deleted
The following link is for the MFC-210 driver download page on Brothers website. Download the appropriate driver for yor operating system, and you should be able to reinstall the printer.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc210c_all
May 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Installing my printer to my new laptop
if its a new laptop is it vista?, if so are you trying to install the printer using the cd you got with it which probably has an xp driver on it? if so it wont install. If you do need the vista driver you will need to visit the manufacturers web site and download and install the driver. If its a new printer also there should be no problem, try in a different usb port and make sure that the driver is installed before you connect the printer
Sep 04, 2007 | Computers & Internet
61 people viewed this question
k24674
jasbo
jasbo
