Question about Pioneer VSX-94TXH
Vsx-94txh i have a 94txh i got a sharp blu ray i hook it up by hdmi i get the blu ray name then it reads the disc then the screen go's blue i have sound. i also tried a sony blu ray it did the same thing. my toshiba hd-dvd player playes fine threw the hdmi.i had a ps3 threw the hdmi it played fine.i got the blu ray player for better sound.now when i hook it up to the samsung 71' 1080p tv playes fine so it has to be in the 94.i tried everthing.changed all the settings in it. PLEASE HELP ME thank you john
  • Anonymous Feb 06, 2008
    I have a similar problem, my VSX-94TXH will not accept a 1080p signal through HDMI from my PS3 . . . the highest res I can set on the PS3 is 1080i. If I manually select a PS3 res of 1080p from the settings menu I just get a blank TV screen (Sony KDS-60A200) the receiver flashes "NOT SUPPORT". Should I ditch the HDMI cable and connect with component?
    Hot Rod
If I'm not mistake, it's dependant on you monitor's ability to display 1080p. I believe the defaul setting on the 94TXH is to read the TV's max resolution and anything above will not feed.
Posted on Sep 07, 2008
Blue ray disc player suddenly will not play blue ray disc?
If you can't get a menu picture from blu ray, check output jacks going from player to tv. if you a picture from blu ray menu, then you may need to clean the lazer eye in blu ray player.
Aug 03, 2015 | Panasonic DMP-BDT300 DVD Player
IS THERE A WAY TO HOOK ETHERNET TO A SHARP BR MODEL BD-HP20U
You can connect it by any way to your BDP. There are cables to connect in between. HDMI, S-Video & AV. After connecting these cables with your TV, select the appropriate selection to video by TV.
Jun 01, 2012 | Sharp AQUOS Blu-ray Disc Player
How to hook up direct tv box,samsung hd tv,pioneer vsx-820 receiver,samsung blue ray bd-c5500
If you're using HDMI cables, which I suggest you do, this is how you set it up.
From the TV, you'll connect an HDMI cable to your receiver.
Connect the blu-ray player to your receiver.
There's a small amount of setup required with the receiver, but it's self explanatory.
Mar 12, 2011 | Pioneer Televison & Video
My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
Apr 24, 2010 | Sharp AQUOS Blu-ray Disc Player
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My sharp blue ray dvd player wont read the discs right...i put the disc in and it play all the commercials but it gets to the movie menu and it freezes...can you help me figure out the problem!!!
anyone having problem sharp aquos bluray reading disc just call 1-800-be-sharp to update your player you will need a computer and a usb 2.0 drive , so you can load update from computer to drive then pull drive from computer to the back of player load load it to player , they tell you all you need to know
Jan 07, 2009 | Sharp AQUOS Blu-ray Disc Player
May sharp lc-52sb55u
Well, there is a way to have the clearest possable picture. Get HD cable TV box that is HDMI compatable and watch only HD channels. Or buy a blu-ray player, hook it up via HDMI and only watch blu-ray disc in 1080p!
Jan 06, 2009 | Sharp LC52SB55U LCD TV
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
BLue ray DVD player
I am not sure about the Sony BDP-S300 Blu-Ray Disc Player: But the Samsung BD-P1000 Blu-Ray Disc Player requires HDMI cable
to give the best resolution (1080p) possible that the TV set is able
to support. Hope this helps.
redthroat@hotmail.com
Nov 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Pioneer VSX-94TXH Logo
281 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
