Question about Garden
Mower runs for 10 minutes when mower deck is lowered and then stops
  • crazytony777 May 11, 2010
    need to know if you cutting grass for 10 minutes then it stop or just running then engage deck and stop?
  • 472 Answers
SOUNDS LIKE ONE OF THE SAFTEY SWICHES ARE STICKING TRY THE SEAT SWICH
Posted on Oct 08, 2009
Engine stops running
if it was a bad gas or water in the gas the car would not start and if it does start it would run really rough it sound to me like you have an over heating problem doe s the temp gauge say its over heating just before it dies?
Oct 01, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Every time I lower my mower board my mower stops or slows down. I just replaced the mandrel and also the belt. When my mower board is raised up all the way the mower works good.
Lower the deck without it running and see if anything is making contact with the mower belt that shouldn't be. Sure sounds to me like you have the belt in a bind when you lower the deck, possibly by not routing the belt in the correct position when you replaced the belt.
Aug 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When deck is lowered blades do not engage
Is the belt in place that drives the blades?
Is the belt at the correct tension?
With the mower engine off.....try to turn each pulley the belt drives and on the mower deck with the mower in up position and or down....do they turn a little......this is to check for a seized bearing on one of the pulleys also look under the deck for something stuck........ jamming a blade.
Also check for the mower belt safety system (which stops the blades quickly when disengaging them) that may be stuck in stop mode.
With the mower engine running.....have some one engage the blades while you look under at the belt system....is the engine driving the belt.....is the belt driving the blades.
DO NOT TOUCH ANYTHING......MOVING OR STOPPED while the engine is trying to drive the blades.
Sep 06, 2009 | Mtd Garden
Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Jun 30, 2009 | Garden
The engine run rough and backfires when deck is lowered with pto
It sounds like your blades may be restricted when you lower them. A possible solution for this problem would be to remove the mower deck and clean out all the dead grass buildup inside the housing.
May 23, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
