Question about Kicker ZX1500.1 Car Audio Amplifier
Amp cuts off...
I got 2 12" L7 and a ZX1500 watt 2 ohm amp. Everything is wired correctly and work just fine as long as i dont turn tha radio too loud!! and thats because the amp i barely turned up!! i figured its cuz tha amp isnt getting enough power. Its only runnin off the front battery of the car. Do i need a second battery or maybe do i need a big capacitor?? how can i fix this so i can turn my amp up and really hear my L7's power???
  • Awax Dec 22, 2007
    the speakers are dual voice coil, and they are wired parallel.
  • 631 Answers
Are the woofers single or dual voice coil?
How many ohms per coil?
If they are dual voice coil, are the coils for each speaker wired in series or parallel?
Are the speakers connected directly to the amp or are the speaker in series (one wire from each speaker connected to the amp?
Have you checked the DC voltage at the amp when you're playing it at high volume (where it cuts off)?
Posted on Dec 22, 2007
Why is my 600watt amp hitting hard but my br as nd new pioneer900 watt is barely makin speakers move I have to turn bass up on radio then it's distorted as nd not hitting at all
First make sure everything is wired correctly, correct polarity and channels. If the amp is a 2/4 channel and 800 watts @ 2ohms, then you would wire your dual voice coil sub at 2 ohms to match the amps output. Same thing if your amp was at 4 ohms, it all depends on how you wire it. Now if your running door speakers off the amp then I would put in an equalizer to better tune it and make sure the amp is set at the proper channels with correct polarity. Double check to make sure your ground,power, and remote wire are getting a good connection
Feb 22, 2015 | Car Audio & Video
What should my setting be on car stereo...Keeps shutting off subs at half available volume.
If your amp is shutting off when you turn up the volume it means that it's clipping. This is very bad for both your subs and amp. The reason this happens is because your amp doesn't supply enough wattage for your subs and the capacitors are being drained of power causing your subs to cut out. As far as ohms this is not a setting. It is resistance and is very very important to have your ohm load correct or it can cause damage to your amp n subs. For a better understanding of ohm loads visit http://www.the12volt.com/caraudio/woofer_configurations.asp and put the number of subs and the ohm value and it will give you the wiring diagrams for the different ohm loads. then u need to look at your amp manual to see what ohm loads it is stable at.
May 14, 2014 | Virtual Reality VR3 Car Amp
I have a 2004 GMC Envoy with a 1000 watt kicker amp with a 2000 watt kicker 15'' L7 and it will dim everything in it, I don't even have to have it really loud what do i do first?
1,what gauge is power wire? Must use 4 ga. minimum 2,what gauge and how long is ground cable? 18 inch maximum 3,battery amps is crucial,check battery fluid level 4,only old school kicker amps are 1 ohm stable,check amp specs
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
May 14, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need help wiring 2 ohm L7's optimally please!
It depends on how long you plan on running your amp when you listen to your music. If you like it loud for a long time, I would kep our speaker load at 2 ohms to keep your amp cooler. If its for car audio competitions where it wont play for so long, ! ohm would give you higher output but heat up your amp faster. Are the subs 2 ohms at each voice coil or 4 ohms? Bridge your voice coils together in parallel then bridge the 2 speakers together in series. That should work fine for you.
Feb 24, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
No sound from subwoofer Solo Baric L7
check the resistance of the sub with a digital multi meter, make sure you dissconect the sub from everything before you check the resistance, if your sub is supposed to be 4 ohms than it should be between 3-5 ohms, if it is under 1 that the sub is blown, while the sub is dissconected from the amp, turn the system on, does it still go into protection?
Jan 17, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
General ?
they are dual 2 ohm all L7 are 2 voice coil per speaker so it is like 2 speakers not 1 the dual 2 ohm version is so you can use 2 speakers wired in series to get a 2 ohm load 2 ohms + 2 ohms = 4 ohms then parralel the 2 at the amp to cut it in half to get 2 ohms. I have full warranties on mine and i dont really sell alot of them any way I prefer the hifonics they sound better last alot longer and take way more power and put out 3 times as much sound. but i can check it out if you have the info.
Sep 17, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to order
The L7 I have is brand new in the box (not a speaker box just the retail packaging box) and the rms is 750 watts RMS and 1500 watts peak, but you are correct they blow easy when you push rated power to them, the hifonics subs will take 1200 watts rms all day long and over 3500 peak for burping at competitions, i run mine at 2000 watts everyday in a daily driver. if you hook 1 dual 4 ohm sub to a zx1000.1 it will be 2 ohm load on the amp so you will get 1000 watts to the sub so if you want to run it slightly underpowered to keep it from blowing use the 750.1 per sub, i can do those at about 250 each shipped
the price is 150 plus 10$ flat rate USPS shipping and yes I accept paypal Wyattconnolly@msn.com .
the warranty starts the day you buy it for 12 months but kicker will not cover burned or blown voice coils, that is why i recommended the hifonics (which is what i use to compete with now) because they put out better quality sound and alot more of it and they will take alot of abuse, if you want boxed speakers ready to go in kicker brand ported boxes I can have them drop shipped right to your door as well, the only reason i am selling the 1 L7 i have so cheap is because a customer ordered it then never paid for it so I am selling it at cost. be careful if you are buying on ebay as you have no warranty at all and you cant force the seller to give you 1 even if they say it has 1. because authorized dealers are not allowed to do internet sales at all so kicker and most other companies will not honor the warranties.
also you dont need 2 amps you can use 1 bigger amp and still run 2 subs just by changing how you wire the subs at the amp. 1 large amp costs less than 2 smaller 1's usually just not with kicker brand
Sep 15, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
L7 wiring options
yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
Aug 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
When i turn my radio up all the way my speakers cut out and then come back on
Yes it is probably too powerful for those speakers. Or the speakers could be defective.
Jan 13, 2007 | Swiss Audio SW12 Car Subwoofer
Kicker ZX1500.1 Car Audio Amplifier Logo
139 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
