Question about HP Pavilion dv6000z Notebook
On my laptop my wifi driver disappeared and it wont upload a new wifi driver. It is running vista if that has any bearing.
Ok ive seen this problem all over the interne and no ones got a solution. I had it and i have seemed to find a solution. start> Device manager and then look under network adaptors and simply enable wireless driver. :)
Posted on Aug 29, 2011
  • 154 Answers
Download your wi-fi driver here.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3224052
Posted on Oct 04, 2009
Need to install wifi driver on gateway 400sd4, win vista,
Go to Gateways web site and download all of the drivers for your Gateway machine and install them.
Mar 22, 2014 | Gateway 400SD4 Notebook
Recently I upgrade my 400sd4 to 512 memory, anew hard drive 160gb and loaded in vista home premium. Now my wireless adapetr linksys wireless-b causes the computer to freeze and not load. I tried loading...
I suspect your problem is with the drivers for that WiFi-B card. You didn't say what the make & model is of that card, but most manufacturers have not updated their older products for Vista (older WiFi-B & not-so-old WiFi-G cards included). If you're trying to force some older Windows 2000 or XP drivers to work in Vista, you're bound to have issues. You may need to replace that card with a new WiFi device that has drivers for Vista. If that device is USB 2.0, you'll need a USB 2.0 PCMCIA card because the built-in USB ports are only 1.1. You should be aware that this laptop supports only 1 PCMCIA card.
There are other problems with your setup, as the hardware of this system just is not up to running Windows Vista well. First, the graphics hardware does not support the shading instructions and DirectX 9.0+ needed for the "Aero" interface included with the Home Premium version of Vista. Second, Vista might run with only 512MB of RAM (the max this laptop will support), but not well; it really "likes" around 2GB of RAM or more. Third, the BIOS of this system (even the latest and last update) does not support 48-bit LBA (logical block addressing), so it can only "see" hard drives up to 137GB. Any hard drive capacity above that will not be seen by the system, and may result in some drive corruption. At best, you will not have use of the full capacity of that 160GB drive.
Lastly, even if you can get all of the Vista drivers needed for this system's chipset and such to work properly, you will probably not be pleased with this system's inability to run the "Aero" interface, or with the performance limitations when running under Vista. My suggestion would be to remove Vista and install Windows XP. That is what this system was designed for, and all the appropriate drivers are readily available -- possibly including the correct one for your Wireless-B card.
Jan 30, 2011 | Gateway 400SD4 Notebook
Me wifi disappear from my laptop
you will need to re install the device driver from the link below
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Toshiba-WiFi-Client-Manager-109107.shtml
Jan 03, 2011 | Toshiba Satellite L355D-S7825 Notebook
Wifi stopped working in my Toshiba A305-s6905 laptop. tried uninstalling and reinstalling drivers, to no avail. What's weird is that every once in a while it will start working on its own, for a couple...
You're using vista or xp? are u using default windows or laptop brand software for wireless connection? are u able to see other wireless networks aside from your own?
Feb 16, 2010 | Computers & Internet
The wifi driver on my laptop as disappeared
Go to your laptop manufacturer's website. Go to the support section and lookup your exact make and model (should be on a sticker on the bottom of the laptop). If you go to the downloads or drivers section in support it should have your wifi driver there to download and install. Just save it to a cd or usb drive and put it into the laptop and run the installation.
Jan 01, 2010 | Computers & Internet
I can't connect to the internet from computer. When I type ipconfig I get Media Disconnected. We have vista on computer
make sure vista recignized your wifi card.
control panel, add/remove hardware- hardware list- if not there then search for new hardware. if it is there, then right click and select drivers at the top dropdown menu then update driver.
Also, go to dell.com find the support section and find drivers and downloads. Enter service tag number and select wireless as your category and install the necessary driver for your dell laptops wifi card
Oct 06, 2009 | Dell Inspiron 1525 Laptop
Broadcom wireless adapater doesn't power ON with switch. DriverOK
go to hp.com choose downloads put in model# dv9000us laptop scroll down to wireless downloads choose vista then: broadcom wireless download vista driver
Aug 30, 2009 | Acer Aspire 5040-3947 Notebook
Realtek RTL8168/8111 device cannot start error code 10
hi
try to connect the new laptop direct to the router with a cable
if it work - there is a problem with the wifi in your computer
try to install the driver from the disk they gave you or from the site
good luck
bernard
http://www.rylwy.com/
Apr 18, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
Wi-fi showing disabled
You may find that the WiFi card needs new drivers. Some particular wifi adapters don't have XP drivers. Compaq are now owned by hewlett packard so go to www.hp.com and search for XP drivers for your wifi card there - luckily HP are very good for providing drivers for XP even on Vista-supplied systems.
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
My acer aspire 5050's wifi doesnt work...
Please Check in device manager, is there any problem with the driver ?
if there is a problem with driver, try to download driver from www.acerpanam.com and install it.
if there isnot any problem, try to enable wireless from the switch (close to external audio port)
Apr 09, 2008 | Acer Aspire 5050-3242 Notebook
HP Pavilion dv6000z Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
