Question about Nikon Coolpix 8700 Digital Camera
Problem taking group type photos with flash - results are dark. wht am i doing wrong
2 Suggested Answers
Char1ieJ
  • 100 Answers
SOURCE: flash pops up, but flash closed warning stays
My E5700 did this a couple of times. The fix for my flash was that the unit wasn't actually popping all the way open. I closed it, then manually poppped open the flash and gave it a gentle upward tug. The flash seemed to lock into position -- and has worked fine since. I hope your fix is as simple as with my E5700.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Posted on Nov 17, 2008
Why is the white background not white?
This is a common problem. The metering and light balance are the reasons that you are having problems achieving good results with your photos.
All cameras on the auto cycle are calibrated for 18% gray. Another words a photo of all white results in 18% gray. A photo of black results in 18% gray. The camera adjusts the shutter speed and aperture to achieve an average light level of 18%. That is why photos of snow always appear gray. To compensate for this characteristic of the cameras an 18 % gray panel is held in front of the camera and than the settings are set.manually. The metering in the camera is now locked and using the same light levels objects will be in their natural level.
A second problem is the white balance. Using flash avoids some of these problems. Adjusting the camera for source lighting type will help the most. The light balance is the cause of discoloration of the objects in the photo. Usually the camera white balance can be set for auto, incandescent, fluorescent, outdoor or flash,
Use a manual setting if it is available on you camera, You need to adjust the settings until you get acceptable results. If the photo is dark add light by reducing the aperture number to a lower number allowing more light. After the aperture is open wide(lowest number) increase the exposure to longer time. With very low light levels a tripod may be necessary.. After doing this once record the numbers for next time.
Nov 15, 2015 | Nikon COOLPIX L100 Digital Camera
When you take pictures either on your phone or your camera why do they have a flash at the back when you want to take pictures
If photo you are taking is in dark area , photo will not be seen as to dark area , so if dark , flash fills in .
Mar 16, 2015 | Cameras
Dark pictures
Check Exposure compensation. If you have a negative number all photos can be dark with flash or no flash.
Nov 22, 2013 | Nikon Inc Nikon Coolpix S01 Silver
Trying to take photos of football game at night. pictures either blurry or too dark. Any fixes?
Are you using a point and shoot camera? If so, unless you get very close, you're not going to get good results. You could try raising the ISO setting and do not use flash. Use a monopod or some sturdy way to hold your camera steady. The best camera for the type of shots you want is a DSLR.
Nov 28, 2009 | Cameras
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
INSIDE PHOTOS ARE DARK AND GRAINY
Regardless of the camera make/model... dark, grainy photos are usually a result of a lighting problem. Looking at the specs for your camera, the flash is only speced for 4m. If you are shooting near or above this you might have trouble. I ended up using an external flash that is triggered by sensing the cameras flash. Pretty inexpensive and pics ar 10x better. Try a local camera shop or B&H Photo (NYC) is where I got mine set up on line.
Jul 24, 2008 | Canon PowerShot A630 Digital Camera
Flash won't fire
charging flash:-
POSSIBLE CAUSE:The camera is recharging the flash.
SOLUTION:It takes longer to charge the flash when the battery is low. If this message appears a lot, replace or recharge the battery.
Dec 28, 2007 | HP Photosmart R607 Digital Camera
All photos underexposed, changing settings does not help
defective shutter curtain opening, it needs pro service. Shutters have life expectancy around 5thou to 10 thou shots.
Jul 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Why do some of my pictures come out dark or with shadows?
Your Polaroid Fun! Digital 320 camera does not have a flash. If pictures are coming out dark, it's because there wasn't enough light in the surroundings when the picture was taken. Remember, it's important to take photos in brightly lit surroundings. When taking pictures indoors, make sure that the room has bright lighting. For best results, take pictures during daylight hours with a combination of indoor and outdoor light, preferably near a window.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Nikon Coolpix 8700 Digital Camera Logo
14 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
