Question about Sewing Machines
My sewing machine is totally jamed up... the wheel wont even move
Were you able to get your machine working? I am having the same problem only I have a headache to go with it as I borrowed the sewing machine. Please email me back.
Posted on Dec 05, 2009
  • shirleysrvpa Dec 07, 2009
    I have looked at the manual. I did not have a problem with the bobbin or thread matting up. It is the gear that is seized and I cannot even turn the knob. I have cleaned and oiled the machine.
  • 277 Answers
First off get out your sewing machine manual.
Then:
Remove the needle & if its the same one that got jammed - throw it away.
Remove your bobbin.
Remove the thread from the machine.
**** Turn off the machine.****
Now.
Following the instruction manual, unscrew & remove the throat plate (needle plate) from the machine.
Using the brush supplied or a clean paintbrush, remove all the lint from the machine. You have a front loading bobbin in your machine so also clean out this area.
Using a bit of the suction from the vacuum cleaner wouldnt hurt either.
Make sure that all fabric & thread from the fabric jam is removed.
It is more than likely that your needle was blunt or broken & the needle has actually pushed the fabric etc into the hole in the throat plate.
Once all that is done then put the throat plate back in, rethread your machine & reinsert the bobbin following the directions in your manual.
If after all that you still have a problem I would take your machine to a repair place & get them to look at it.""
Posted on Oct 04, 2009
My sewing machine has stopped working, it was working ok , just a bit noisier than usual but now the needle wont move at all, even if i try to turn the wheel by hand
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Mar 17, 2016 | Singer Inspiration 4210 Mechanical Sewing...
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
My hand wheel is not moving. How do I correct that?
Something is "jamed" material or thread in the mechanism. Look carefully top and bottom. move wheel just slightly to help see what is in the "works"
Apr 08, 2015 | Sewing Machines
Why is my machine jamed
Sounds like a thread jam ! Open bobbin case housing remove bobbin and clean away thread ! Do not force the balance wheel to turn or you will knock out the timing !
Aug 25, 2014 | Tacsew 20U43 Sewing Machine
When I use the wheel or foot petal my machine wont go up and down any more
your machine is most likely "gummy". when sewing machines sit the oils get sticky, particularly in entry level machines as they use cheaper oil. there could also be some tangled threads and lint that are adding to the problem. if your machine was shipped or dropped something may have been bent or broken out of alignment. at best, your machien needs a labor intensive process of dissassembly cleaning and re-lubricating. i would there is probably not a quick fix. i would recommend taking it to a sewing machine repair shop. call ahead to make sure they give free estimates. you may have to leave it for a time but if they charge for estimates then they're not a good shop. i am a sewing mechanic of 20 yrs
Feb 08, 2013 | Brother LS-1520 Mechanical Sewing Machine
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
I have a Kenmore 1516 that will not sew. The
If you can take the top cover off, try spraying the whole machine works with WD-40. Let it sit for a few hours to start working and then try to move things slowly.. If things start to loosen up but not totally move, spray it again and let it sit over night and try things again.
Kelley
Apr 26, 2009 | Sewing Machines
The needle wont move at all?
Hello we had the same problem with our sewing machine. After playing with it we found there is a bobbin winding assembly lever that moves back and forth. By moving it the needle moved. This helped us. Hope it helps you. embreyR97@yahoo.com if you have questions.
Jan 05, 2009 | Brother XL-5130 Mechanical Sewing Machine
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
Kenmore 385 series
The bobbin case is most likely not adjusted properly. The bobbin case has a small piece of metal that can be loosened with a screwdriver. Once it is loose you need to move it to a point that won't allow the case to move. The bobbin case must only be moved to a point to stop the bobbin case from movement. If it is too tight it will cause the machine from sewing.
Jul 05, 2017 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
112 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
