Question about Nokia N70 Cellular Phone
Heating when using - Nokia N70 Cellular Phone
  • 10,515 Answers
It's my Humble request, do not offer solution because you need to answer to maintain Premium Rank.
Agreed, Overheating might be there when the cellphone is charging. But, Have you checked the Battery ?
Yes, - It uses Li-Ion ( BL-5C ). Nokia already accepted that this is a serious concern.Kindly read the article :-
http://www.mydigitallife.info/2007/08/14/nokia-confirmed-genuine-bl-5c-battery-overheat-issue/
Warm is OK!! Even Hot is fine if you are using it. But, if it's Overheating all the time, better to replace the Battery.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 06, 2009
    Problem Solver:
  • 3 Answers
I used to have the same problem with my n70, it heats up and drains my battery, i just reformat it by *#7370# it will reformat your phone, and my heating problem is gone.
Posted on Oct 05, 2009
    President:
  • 1,884 Answers
Little bit heating is acceptable as after all it is working. It should not heat up too much. When you are using it and also have the charger connected to it naturally it will heat up as the battery is discharging and charging simultaneously. I have a Nokia E71 and use it as a wifi hotspot to access the net on my laptop, you got to see it heat up. And I also keep charging it as the battery drains very fast if used as a hotspot. But thats how it is. So, dont worry unless it heats up very much. If it does then show it to Nokia Care.
Posted on Oct 04, 2009
  • Nokia Master
  • 805 Answers
May be your cell battery amphare is less than 1012. if it then change your battery. if not solve then i think your cell is short circuit. thanks
WHAT DOES IT MEAN WHEN HEAT IS SET 66 AUX IS FLASHING
If it is a heat pump if the ambient I door temp is not than 3 degree s lower than 66 it utilizes the aux heat ( heat strips) to help the unit achieve your desired temperature set point faster. Also the heat pump does need help if trying to overcome really cold temperatures. Once set point is achieved the heat pump should be able to keep the home at the set point without aux heat. But the flashing may just be to let you know that the heat strips are in use at the current time. See if when the temperature gets close to your set temp if it goes away. If not a heat pump it may always flash to just tell you heat strips are in use. Some homes mostly trailers only have heat strips but on heat pumps heat strips are there to help heat pump get to your desired temp. But when your heat pump can maintain the temp without the strips is where it saves power. Also heat pump thermostat hVe emergency heat settings. This scares alot of people but if your heat pump isn't working and you have to switch it to emergency heat until you can get it fixed,. That means that the system is only using heat strips and not utilizing heat pump at all. Power bill may be a little higher but remember, most trailer homes only have heat strips and if you do not use emergency heat in this situation your heat strips will only heat home 3 degrees below set point on thermostat to allow heat pump to bring it up the other 3 degrees. If heat pump isn't working correctly you will always be 3 degrees colder than what you set you thermostat at. Maybe too much info but it's prolly just your aux heat on helping system achieve the desired temp you set thermostat too.
Oct 24, 2016 | Heating & Cooling
Tip
Home Electric Heat Heating and Electric
Electric heat can come in many different forms. Some of these methods are resistance heating, electric arc heating, induction heating, and dielectric heating. The most common of these is the resistance heating. With the resistance heating of electric baseboard heating, water heating and kitchen ranges, you don't have to worry about carbon monoxide or unvented gases. However, direct with electric is really not considered ecologically sound because most electricity uses fossil fuels. This is because about two-thirds of the energy of the fuel is lost within the power stations, and in transmission line losses.
Some of the most popular choices for electric heating systems are thermal storage systems, electric radiant heating, hydronic electric heating and even convective heating. You can also install an off-peak system that can save money and also give you the convenience of electric heat. An example of an off-peak electric heating system that is very common today is an electric plenum heater. Another newer form of heating is a convective electric heating system. Both use electric heaters to heat the air that is then circulated with blowers throughout your home.
Electric heating has several unique advantages. It can be precisely controlled to allow a uniformity of temperature within very narrow limits, it is cleaner than many other methods of heating. It does not involve any combustion and it is considered very safe because it is protected from overloading by automatic breakers. It is quick to use easy to adjust and it is relatively quiet. The main disadvantages of electric heating in industry are the higher cost of electrical energy compared to direct use of fuel, and the capital cost of both the electric heating unit itself and the electrical wiring required to deliver large quantities of electrical energy to the point of use.
Electric heat does have a place. One place where it does shine is in a seasonal cottage that will only be used a few times a year. It is very easy to shut down the heat and turn it back on when you get back there. There is also very little that can go wrong or go bad from the long periods of non-use. For this situation electric is a very good choice. This is really the only situation in which I recommend electric heating.
As you can easily see, electric heating has some advantages and some disadvantages. The cost of electricity has continued to rise and will be skyrocketing even higher in the future. Many states have or will be deregulated electric or are going to do so in the very near future. With the future uncertainty of the cost of electric and the great amount of waste in the transmission system of electric, many owners of electric heating systems are debating whether or not to convert to hydronic baseboard heating. With the super high efficiency of today's gas and oil boilers, they are quickly becoming much more attractive to many homeowners. Combining a high efficiency gas or oil boiler with hot water baseboard or radiant heating gives you great comfort and will give you low utility costs for many years to come.
on Dec 25, 2009 | Heating & Cooling
Honeywell troubleshooting
Emergency heat is the setting that shows that your heat strips are activated. Sometimes people do not wire up the heat strips at all as the use a great deal more power than the normal heat pump uses. The problem is that a heat pump comes to a point where it is not efficient at about 28 degrees and this is where you need the heat strips or if you want to heat the house quickly which a heat pump will not do. Heat strips are located in the ductwork and act like a space heater. A H/A tech is probably needed to check this stuff out for you.
Nov 15, 2013 | Cars & Trucks
What kind of heat source should I use to properly heat a tank for a box turtle?
There are two good heat sources that can be used for box turtles:
Overhead incandescent heat lights
Under tank heating pads
Or, you could use a combination of the two to provide your box turtle with great day/night heat areas.
Sep 04, 2012 | Aqueon Reptile
I dont know how to use induction cooker.it has no numbers to reduce the heat.things will burn very fast
You can use to set the timing in order of the heat required. Also using the grade rating of the heating coupled with the time set, the food can be easily heated without burning.
To start with use low heat and long time, the try with medium heat and lesser time and then choose high heat and short time. You must be able to use the settings accordingg to your requirement.
Hope this advice helps
Aug 27, 2010 | Microwave Ovens
My heat pump is shot and is operating off the emergency heat. Can I just continue to use it this way or do I have to replace the heat pump?
You mean you are using the Emergency heat setting instead of the heat pump????...You're using Natural gas only now tn emergency heat????That's fine...I wouldn't replace a heat pump if you have Natural gas....it's too expensive compared to Gas....you may be able to still use the heat pump as an Air Conditioner only , it depends on what's wrong with it...otherwise you will have to get a Central Air unit instead...cheaper and just use the Gas for heat
Oct 29, 2009 | Amana PTH123B25AJ Heat Pump Air...
EM HEAT.... does it stand for ECONOMY HEAT or EMERGENCY HEAT? They both conflict. Someone's misinformed.
It stands for Emergency Heat. (Back up heat) . Normally you will find it on heat pumps. It's used manually when the compressor goes out on a heat pump. It's used automatically by the unit when it's so cold outside the heat pump can't keep up. This happens when there is not enough heat in the air to draw heat from. This happens at around 23 degrees. I hope this explains what emergency heat is and what it's used for.
Oct 16, 2009 | Ruud Central System Air Conditioner
Abbreviation definitions.
Economy Mode = EM
Auxelary Mode = AUX
in em mode heat pump does most of the work in aux either an electric heating element is used or gas depending on if it is gas or all electric
What's the difference between EM HEAT and AUX HEAT?
Sorry, neither of these answers are completely correct.
You have a heat pump (or the wrong thermostat). Let's assume you have a heat pump.
In air conditioning mode, it works like every air conditioner you have ever had, but...
In heat mode, it reverses its operation. Have you ever felt the air coming out of the outdoor unit of your A/C unit? It's hot, isn't it. And the air coming out of the indoor unit (out of the registers) is cold. Now for a heat pump to produce heat it simply runs the air conditioner in reverse and the heat comes out in the house and the cold is released outside. Neat, huh!
Here's the problem with heat pumps...when it is really cold outside the heat pump can't produce enough heat to heat your home. So it has an additional heat source called "Auxiliary Heat". This heat comes on automatically when the house doesn't get warm enough. The source of this heat is based on the region of the country you are in. North/Northeast generally have oil heat, other regions have gas, and still others have to use electricity to heat. In Texas, we usually use electricity as the supplementary heat on heat pumps. VERY EXPENSIVE!
Now the "Emergency Heat"...this is exactly as stated in Solution #2. This is manually turned on by YOU at the thermostat when your heat pump fails. This turns on the auxilliary heaters and turns off the heat pump (remember, the reverse air conditioner). Again, this can be quite expensive to run if your heat source uses electricity! Gas and oil may be cheaper. The emergency heat is only designed (normally) to keep the house livable (not comfortable) until the Heating Tech can get out to you and fix your heat pump.
Something else you should know. It is normal for a heat pump's outdoor coil to frost up during heating mode. It will detect this and go into DEFROST mode and melt the frost off the coil. While it is doing this, it will turn on the auxilliary heater to keep the air blowing in the house at a reasonable "warm" temperature, but it will not be as hot as normal. In fact, heat pumps produce a lower temperature heat than traditional heaters. So the air may feel cooler during heating than you are use to anyway. This is normal and is not a sign of a problem.
So what do you do: Set your thermostat to the temperature you want and set the controls for HEAT/COOL and FAN-AUTO/ON and leave the EMERG HEAT off unless your heat pump breaks.
As always, keep your filters clean and your outdoor unit's coils clean and free of debris.
Hope this explains your question for you!
CAN i USE THE HEAT GUN TO WELD VYNAL TOGETHER
You need the proper type of heat gun and the proper type of filler. It is mainly used for thicknesses over 1/4". The vinyl on a lounge would melt away from the ambient heat created by the gun.
Mar 11, 2009 | Master Appliance 650DG F MASTERMITE MASTER...
Nokia N70 Cellular Phone Logo
760 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
