Question about Broan-NuTone Allure II QS230SS Kitchen Hood
How do you change a halogen bulb in my dacor range hood
I don't want to break it. I can not figure out how to get the lense cover off
  • 3 more comments
  • jsully Dec 29, 2007
    Thanks for your help!! I really appreciate it.
  • Kevin Jan 09, 2008
    Can anyone tell me what type of halogen bulb these units take - Home Depot, Lowes & Menards do NOT carry a bulb that fits.....???
    Kevin
  • scottiee Feb 06, 2008
    I need to change the light buld in a range master rmp17000. How do i get the lens off to get to the bulb.
  • Anonymous Feb 28, 2008
    NEED SUCTION CUP
  • Anonymous Mar 30, 2014
    PE050034 Halogen Light Bulb
Believe it or not - they just unscrew like regular light bulbs. There is supposed to be a suction cup that came with the hood to replace the bulb - we lost ours. I was able to remove it by using a little bit of pressure on the face of the bulb and twisting it back and forth. The other bulb was stuck, so I made a "handle" using duct tape on the face of the bulb.
Posted on Dec 28, 2007
  • fareid Oct 25, 2010
    We wrap the ductape on our palm, sticky side out.and twist to the left. with the sticky side on the lamp's surface. (make sure they are all cool). pressure-twist left-wise (migh need to loosen first by twisting little right little left, but keep twisting to the left and it will start coming off. Thanks dorkola
1. Take the filter screen out.
2. You can reach and unscrew the light at the base, very easily.
3. Screw in the new light (make sure you align the Edison threads with the holes in the screen)
4. Replace the filter screen..
Posted on May 06, 2008
  • 38 Answers
The lens cover comes off with a flat head screw driver. Its only snapped on. I do service calls for broan/nutone
Inventex.com
Posted on Jun 14, 2008
    New Friend:
  • 7 Answers
The halogen medium base bulbs used in the Allure Broan over the stove hoods are both difficult to screw in to make contact to light up, as well as unscrew to replace. Since there is barely room to get your finger tips on the edge of the bulb and sheet metal hood I used a thin piece of rubber used to help grip taking lids off bottles and jars. I remove the filter screen so I could grip the back of the bulb socket with one hand and apply an opposing force with the other as I had to push slightly up gripping the edge of the bulb with the thin piece of rubber twisting counter clockwise to loosen the bulb. It is not like taking a bulb out of a lamp socket as it does take some finger strength to firmly squeeze the edge of the bulb to break it loose.
Posted on Jul 05, 2015
Take the vent off and strong long fingers will unscrew them.
Posted on Jan 13, 2008
Replace license plate light 2002 silverado
Unscrew the bulb without removing the bulb housing if possible. Don't break any wiring!
Dec 02, 2017 | 2002 GMC Yukon XL
I want to take the side mounted speakers off the mitsubishi cs-40505 but can't figure out how they come off and don't want to break them.
Hello; there are almost Always screws holding them on. There are very likely small rubber or plastic covers to cover up where the screws are. Look around where the speakers are mounted and then look for circular or other shaped covers that you can peel or pry off. Another possibility is the shape of the whole front/rear cabinet is made to "look" like they are removable. In this case a Chainsaw will do the job. John
Jul 06, 2011 | Televison & Video
I want to know how i can get to my front lights with out breaking to covers ?
Your bulbs come out from the rear of the lenses. Look behind the grill for a top cover that comes off and lets you gain access to the back side of the lenses. The bulbs will twist 1/4 turn to pop out. They will have a tab that holds the main wiring plug in the receptacle. Carefully lift the tab and pull the wiring plug loose. When installing the new bulbs do not touch the glass, it does shorten the life of the new bulb.
Dec 30, 2009 | 1996 Mercury Grand Marquis
How to replace a nessan sentrs break light
Check inside the trunk; to keep the lenses tight outside, many of the rear lights are changed from the trunk with twist or pull out sockets. They may be covered by the mat material in the corners.
Oct 25, 2009 | 2007 Nissan Sentra 2.0 SL Sedan
Removing tailght lenses cover?
drop the tail gate and there are screws where the gate was and if i remember correctly they are torx screws and u just pull straight out the whole cover cause it's clipped into place. when u have the whole tail lamp in your hands unplug the power connecter then use a phillips and unscrew the housing and replace the bulbs. The bulbs are a real pain in the *** cause they have that small little metal piece that breaks all the fricken time. well it does for me anyways. good luck
May 26, 2009 | 2005 Dodge Ram
Need to replace cargo & third break light how do i
if its the same as an 06 Tundra, you should be able to remove the lense cover from the back of your truck cab with a screwdriver and pull the light bulbs out...Do not remove the screws below the lense cover that removes the fixture, they have a screw insert that will fall into your truck's body and get lost.....hehehehe I learned that from my own experience...good luck!
Mar 04, 2009 | 2008 Toyota Tundra
Nokia 6600 Fold
Got it, Lift the two corners near the camera lense but a little (so that they pop free) then slide the cover down it should come off then
Cheers
Jan 29, 2009 | Nokia 6600 fold Cellular Phone
Singer Steam Press PRO9S
I have a Singer steam press Pro-9S, the top plate is loose from the screws holding the hot plate and the cover arm, I like to know how to remove the hot plate cover from the arm to tighten those screws. Thank you.
Feb 18, 2008 | Irons
Front screen cover
Hammer, waay easier and safer to remove the back top cover, the front is flimsy when it is removed from the set and if you crack one or both of the screens they cost big money. Be advised that the top back cover has a large mirror bolted to it and it to is expensive. Have 2 people when the last screw is taken out so you don`t break the mirror, not real heavy but very awkward for one person. Once you remove this back cover you can clean the mirror, inside of front screen and all 3 lenses. NO WINDEX, DAMP, lint free cloth and warm water only. Good Luck & Happy Holidays, BMW Rider
Dec 04, 2007 | RCA P52960 52" Rear Projection Television
Lense cover keeps falling off
The spring must have grown tired, or displaced. If you don?t want to loose it in the meantime, you can glue a string one side to the cover and one side to the camera?s body using small points of super glue. But a more creative solution would be to get to a cannon selling shop and nag them to help you get a new one, or go to a second hand shop and look for a standard cover that?s a good fit for your lense.
Feb 21, 2006 | Canon PowerShot S2 IS Digital Camera
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
10,797 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Steve Allison
Steve Allison
Marvin
Marvin
Paul Bade
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
