Question about Kenmore Refrigerators
Door rub bottom On model #59672289200 The upper door has a rough spot on the left side and the door does not close all the way unless you push hard.
    Sergeant:
  • 316 Answers
Adjust the door with the screws at the hindges.
Posted on Oct 04, 2009
I bought a house that has this dishwasher. I do not know how old it is. It does a great job of cleaning dishes but three problems: 1. how do you know when it is finished? it has no lights, only a plain...
There is an indicator light on the top left side of the door, it's on when running and flashes for about an hour when done. There should be a reflector attached to the bottom of the countertop, with double sided tape, above the light, allowing you to see the light when the door is closed. It looks like a piece of clear plastic about 2x2 inches. To turn the dishwasher off, when not in use, you need to press the off button, and press the on button when you want to use it, that's normal for your dishwasher. The door latch might need a little adjustment. On the top edge of the dishwasher, in the center there is a small metal latch sticking out. You can loosen the screws and move the latch out, just a little, tighten it up again and see if that makes it easer to latch the door. Don't move it out too much or it could start leaking from the door seals. Also make sure the door is not rubbing on the cabinetry or countertop. The bottom basket should just have tines for 2 rows of plates, you should be able to fold one side down. Silverware goes in the cutlery tray at the very top of the dishwasher.
Mar 28, 2015 | Miele 24 in. Incognito G843SCVi Built-In...
Sharp AR-M550N close the upper left side cover
Close the lower left side cover error :
this problem is for under the left door
for fix this problem push the all part on left side
under the door is important
mehdi ebrahimi iran,karaj
Oct 19, 2012 | Sharp AR-M550N Copier
Model KEBC277 Kitchenaid oven - I need to remove the upper door, but can't figure out how to unlatch the hinge
there will be two hinge latches that you flip to stop the door from closing. This will allow you to push the door in and then pull out the bottom. I do not suggenst using the handle as it may cause damage. use one hand on either side of the door, push the door shut and then lift up a bit and pull the hinges out of the holes.
Oct 26, 2011 | Ovens
My Bosch economic cooler has a door problem. It no longer shuts automatically unless one pushes it hard to shut it.
check for food or shelves protruding. Check if door is rubbing on the bottom, sometimes scrape marks are evident. check to see if gaskets are sticky if so clean them and apply thin layer of petroleum jelly. Depending on the model sometimes the closing cams are broken on the bottom hinge.
Apr 14, 2011 | Bosch Refrigerators
Samsung Refrigerator opening door is very hard.
Very common problem, due to full power of magnetic gasket. It's my own experience but some other brand, the solution is:
Don't close the door roughly or even don't allow fast to close automatically. Close door gently. And take some talcum powder (face powder) rub nicely on door gasket all four sides. Repeat it at least once in a month, until when you can open door smoothly. Thanks, helpful?
Jan 27, 2011 | Samsung RB215LASH
SYMPTOMS OF BALL JOINT WEAR
If you make a hard right or left hand turn (with steering wheel turned until it stops) you'll hear and feel a pop sensation.When you drive over potholes you'll feel a slight pull to one side.If it is one of the upper balljoints,you can grab the tire with both hands near the top(11 and 1 o'clock) and pull the wheel back and forth.You will feel looseness if the upper balljoint is bad.
Nov 01, 2009 | 2002 Ford Taurus
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
CD door won't open
New CDs may have some rough spots around the inner and outer edges. If such a CD is used, this unit may reject the CD. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Dec 31, 2005 | Jensen JCR-280 Shelf System
Refrigerators Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
