I have a RS232 /RS485 converter. Need to connect it by a wiring digram to a PTZ control box for a CCTV system, I need to know how to wire it up to test it. The converter is model NA 485s, and the control box is from China so no readable info
  • 631 Answers
SOURCE: System Remote Control Wire.
Wal Mart generally has 4g wiring kits for ~$40. Some of the kits contain everything you'll need to install your amp (including RCA cables, fuses and fuse holders).
If you want to understand more about car audio installation, read through the following site:
bcae1.com
Read the following pages specifically:
Installation Primer
Wire
Fuses
Amplifiers
Head Unit
Posted on Dec 29, 2007
SOURCE: RS-422 connection RJ12
What I was told through the mfg. was:
pins 1,8 =NC
pins 2,7= Chassis Ground
Pin 3= TX-
Pin 4= TX+
Pin 5= RX-
Pin 6= RX+
This would actually be a RJ45 (8pin) but uses the 6 pin cable and only 4 com wires.
Evidentally there is no standard for the pin usages for serial communications with RJ connectors. So this information might not be valid for other equipment.
Posted on Jan 21, 2009
SOURCE: installing a pelco ptz camera using my old controller
pelco cctv ptz doec not moving can you give me a solution?thanks a lot.
Posted on Feb 13, 2009
  • 290 Answers
SOURCE: wiring digram for 08 mazda 6 radio install
not sure how much the radio or harness changed from 2006 until now, but here is a link to some Mazda radio schematics:
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Mazda.html
Posted on Mar 31, 2009
etirbynnor
  • 655 Answers
SOURCE: sony wiring digram for in dash cd player model cdx-gt10w
Hello everroth,
You can download a copy of the manual from Sony here. It's only a 2 page PDF document and figure 3 shows the wiring color codes and wiring diagram.
Hope this helps.
Posted on May 04, 2009
Can the exsisting protacal be modified?
Good question. What camera? Most cameras cannot be modified. Some newer cameras are multiple protocols. Need more information.
Sep 25, 2014 | CCTV Camera Pros MON-LCD35P Test Monitor...
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
Only works as a CCTV
if you have a cctv and want to run the hdtv you will need a set top box to convert the signal from digital to analogue for the cctv to read it aerial wire to the set top box then to the tv inlet. and 2 audio wires from the box to the tv - Color to color is the trick
Jun 21, 2013 | Televison & Video
Have older rca xl 100 13 inch tv and can`t seem to get a picture with a hd cctv camera the tv wirk find if I hook it up to dish net work. the power supply is a 2 amp 12 volt system and using wire with...
Is the HD CCTV camera analog compatible? I would imagine not if it says HD in it's name. But you can try using a converter box with it because if the camera is outputting HD you need to convert it to analog which the TV can understand.
Oct 31, 2012 | Televison & Video
How do the wires hook up in a bosch\phillips ltc 0829
Dear Jesse Diaz,
please find below the link to installation guides that should help you with the problem:
http://resource.boschsecurity.com/documents/Installation_Guide_enUS_2263492107.pdf
http://resource.boschsecurity.com/documents/Installation_Guide_enUS_2263526411.pdf
http://resource.boschsecurity.com/documents/Installation_Guide_enUS_2250534027.pdf
Best regards
Andrea Goehler
on behalf of Bosch Security Systems
Sep 11, 2012 | Philips Bosch Ltc 0829/20 Autodome Color...
Does it supports any brand of cctv cameras or will there be any incompatibility with same brand..
It support all brand of CCTV.
for PTZ CCTV, It has to have the Pelco protocol so the WJ-HD716 can control the camera.
in that case, the connection will use the RS485.
Oct 19, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
Is this scanner only able to connect via USB?
HELLO,
the kit part number you have is a usb power plus kit, what you need is cable part number:
CBA-U01-S07ZAR
If you want to order one, let me know. I can be reached at 7275714159 x251
Thank you,
Kim GAnoe
Mar 18, 2010 | Symbol DS6700 (DS6707SRWU0300ZR) Barcode...
Installing a pelco ptz camera using my old controller
Aug 18, 2008 | Cameras
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
