Question about Compaq AlphaServer 1200
Error code set in packet-No such variable name.Index: 1.
Error: Non-algebraic variable in expression
Non-algebraic variable in expression: error 790
If a is the name of a PIC, GDB, MAC, FIG, etc., a+1 is invalid. Use a different variable name in the expression or delete the variable.
Apr 22, 2015 | Texas Instruments TI-89 Graphing Calc...
How do I fix server error 8004849
This is from Microsoft:-
If you receive Server Error: 0x80048849 and/ or 0x80048820 in Windows Live Mail at home or while you're in your regular network, it may be due to the setting of the MTU (Maximum Transmission Unit) on the mail client.
If you get this synchronization error at a coffee shop, airport or a place from where you don't usually connect to the internet, we suggest synchronizing mail on your regular internet connection.
When the MTU setting on the mail client is larger than the MTU settings configured on network devices between your mail client and the mail client servers, some data packets may be lost, causing mail synchronization to fail.
Follow the steps given below to fix synchronization errors due to mismatched MTU settings:
Determine the MTU setting on your network device
Apply the MTU setting to your mail client
This is a trial and error process, and will be different for each user. You may have to repeat the procedure below a few times, before you can find out the MTU setting of your network device. Follow the steps below:
Open command prompt
Click Start ? Run ? Type cmd
In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1500
Notes:
The <Mail server address> is the IP address of the mail server that you are unable to synchronize with.
For Hotmail, 65.55.33.106 is the IP address for DeltaSync (mail.services.live.com).In this document we will be using this IP address as an example.
In the -l 1500, 1500 is the max MTU for Ethernet connections.
You may get an error like this (100% packet loss):
C:\Users\username>ping 65.55.33.106 -f -l 1500
Pinging 65.55.33.106 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 65.55.33.106:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
If you received the error above, subtract 28 from the 1500 bytes of data. In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1472
If you get a 0% Packet Loss with 1472, it means the MTU setting of your configured network is 1472
Note: If you continue to receive the error described in (b) above, repeat the above steps by subtracting 28 from 1472 bytes of data. Repeat these steps until you get a message for 0% packet loss. If you were able to communicate with the mail server at an MTU size of 1424, you will receive the following:
C:\Users\username>ping 65.55.33.106 -f -l 1424
Pinging 65.55.33.106 with 1424 bytes of data:
Reply from 65.55.33.106: bytes=1424 time=230ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=196ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=162ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=163ms TTL=241
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 230ms, Average = 187ms
Open command prompt as administrator (you must be an admin on the computer)
netsh int ip show int
You will receive a message similar to the following. Find the connection name that you use to connect to the internet and note the Idx value
C:\Users\Username>netsh int ip show int
Idx Met MTU State Name
1 50 1472 connected Loopback Pseudo-Interface 1
11 20 1472 connected Local Area Connection
To apply the correct MTU setting on your mail client, type the following in command prompt:
netsh int ip set interface <Idx value> mtu= <MTU setting of your router> store=persistent
Press Enter
For example, if the correct MTU setting was 1424 and Idx value of your connection was 11, you will type:
netsh int ip set interface 11 mtu=1424 store=persistent
If (c ) was successful, you will receive the confirmation message "Ok"
Exit command prompt
Restart your computer
Open WL Mail and see if the issue persists.
have Windows Vista Home Premium Recently unable to send or recieve Window...
Feb 12, 2015 | Toshiba Computers & Internet
Error:non-algebraic variable in expression
Non-algebraic variable in expression error may occur if a is the name of a PIC, GDB, MAC, FIG, etc., a+1 is invalid. Use a different variable name in the expression or delete the variable
Mar 21, 2012 | Texas Instruments TI-89 Calculator
Internet setting
i m sending u some network's settings...
send me ur network's name ....i will send u thier settings
For idea-
account name-spicegprs
proxy - enable
use pref. access pt.- No
data bearer- packet data
packet data acc. pt. - spicegprs
network type - IPv4
For AIRCEL-
account name-aircelgprs
proxy - enable
packet data acc. pt. - aircelgprs
network type - IPv4
FOR AIRTEL-
account name-mobileoffice
proxy - enable
packet data acc. pt. - mobile office
network type - IPv4
Dec 22, 2010 | Nokia 5320 XpressMusic Cellular Phone
Why do we need to declare variables?
I'm assuming you are referring to declaring variables in Procedural programming languages such as Java. Variables need to be declared for several different reasons, some of which include helping the computer reserve space in memory for variables to be stored and it also plays a part in the various stages of converting the source code, i.e. the code that you type in VB or Java, into machine code which is a series of binary digits that the computer can actually understand. It helps the computer in debugging the code for errors. In the first stage of code conversion, lexical analysis, information about the variable names is stored. In the next stage, Syntax analysis, the code is checked to be grammatically correct according to the rules of Backus Naur Form, i.e. if a key word such as PRINT is typed in as PLINT the computer will treat this as a variable name and since no information about this variable name has been entered in the lexical analysis stage it knows that an error has been made.
Hope this helps!
Dec 11, 2010 | Computers & Internet
How can i activate gprs settings on my n73 mobile?
If your settings still don't work you can choose to manually set up your phone
1. Go to Menu > Tools > Settings > Connection
2. Select Access Points > Options > New access point > Use default settings
3. Name the connection
4. Set Data bearer to Packet data
5. Fill in access point name (APN); http://www.nav4all.com/languages/enguk/gprs_listcountries.php?m=N73%20Music%20Edition to check your settings
6. Set Username (None)
7. Set Promt password to No
8. Set Password (blank)
9. Set Authentication to Normal
10. Set Homepage to whatever site you like
11. Back * 2
12. Select Packet data
13. Set Packet data conn. to When available
14. Leave Access point blank
15. Finished
After setting up your phone continue with step 2
Step 2: Install Nav4All on your mobile phone*
Switch on the Bluetooth GPS sensor so that it can be automatically coupled to the mobile phone right after installing Nav4All.
Installation is done in four steps:
Step 1:
Switch on the GPS sensor.
Step 2:
Go to
http://www.nav4all.com/n4anews/index.php?lan= using your phone's web browser and follow the instructions. Step 3:
After downloading, Nav4All must be started up. Follow the instruction choices:
a) The display language
b) The audio language
c) The GPS sensor
Step 4:
Nav4All can be now found under Applications.
Tip: consult the mobile phone manual on how to start up the Nav4All application.
This varies from one mobile phone to the other.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 24, 2010 | Nokia Cell Phones
Trying to write a loop using excel text boxes such as: Dim x as integer for x= 0 to 100 textbox(x).backcolor=vbWhite x=x+1 next x Not working any thoughts thanks
You don't say how your program is not working, but one of the problems with your code is where you have x=x+1. Loops using For Next don't need a statement to add 1 to the value of x. The variable x will automatically be increased by 1 each time the program reaches the Next x statement. Your program should be
Dim x as integer: For x=0 to 100: textbox(x).backcolor=vbWhite: Next x
Have fun
Nov 02, 2009 | Microsoft Excel for PC
I cannot plot graph in my Ti 89 graphing calculator
That means one (or more) of the variables you have in your function is not defined. Check to make sure you didn't misspell any variable name. Also, check to make sure you didn't run two variable names together. "ab" is the variable ab, not a times b.
Mar 19, 2009 | Texas Instruments TI-84 Plus Calculator
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Feb 28, 2009 | Sun Java Programming Language (cdj-275)
Compaq AlphaServer 1200 Logo
90 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
