Question about Dymo LabelWriter Thermal Printer
The labels continueously come out printing garbage
    Scholar:
  • 40 Answers
Sounds like an incorrect print driver or a corupted print driver. The driver probably needs to be deleted and then reinstalled. Go to the control panel, and then to add / remove printers. first remove the print driver and then reinstall it. If your printer came with a disk you can use that but sometimes the driver will be updated to fix problems like this so it is best to check online and download the latest version.
Posted on Oct 04, 2009
MY PRINTER ZEBRA GK888T SKIPS LABELS WHEN PRINTING. IT CANT RECOGNIZE GAPS BETWEEN LABELS. CALIBRATED MANY TIMES ALREADY
go to printer properties , check in the options and make sure it there should be printing in continuous not with gaps,
there will be one option print and one tab will be there with options to either print in continuous or with gaps, so select continuous from the tab and save the changes it will work
Best regards
Waqar Ahmed shahUAE
Feb 07, 2014 | Zebra tlp2844ps Thermal Label Printer
We have a 160s printer and we had to change computers the program was based on. We went from a dual core to a quad core with more memory and basically cloned the hard drives to accomidate everything. The...
If your running this printer off a serial port you may be getting a buffer overrun. I'm guessing that your using X on X off Handshaking so perhaps you could fix the problem by slowing down the baud rate. You need to change this both on the printer and on the PC that's driving it.
You will notice that there may be a slow down in "First Label Out" but it may solve the issue. If that doesn't do it then you might want DTR / DSR handshaking but you may need a different interface cable that support it.
Regards,
mikeo@acebarcode.com
Feb 22, 2011 | Zebra S Series 160S Thermal Printer
I have a Zebra Stripe 600. I am trying to print a
Ok, when you say continuous...do you mean it is a roll of label material that does not have gaps in between? If it has gaps...it is NOT a continuous label and you probably have the driver settings set as continuous feed and not gap as it should be....
Call BarcodeWarehouse.biz - they will help you with any problems you have!
Aug 03, 2009 | Zebra Stripe Thermal Label Printer
Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Mar 06, 2009 | Zebra LP 2844 Thermal Printer
Cognitive Del Sol LX continually spitting out labels
Try calibrating the printer. This can be accomplished through printer driver under 'printing preferences' or the Cognitive Printer Setup Utility.
Dec 13, 2008 | ATSI Holdings COGNITIVE (LDD42-2083-013)...
Just changed labels to 99010 and can no longer print
Did you change the label type in the printing preferences?
Apr 07, 2008 | Dymo LabelWriter 400 Thermal Printer
Motor throtting
This error appears when the printer has worked for more than 1 hours continuous, and to protect the printer. Wait a few minutes for printer to cool and continue with your printing.
Jan 22, 2008 | Datamax I-4208 Thermal Label Printer
Okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Aug 06, 2007 | OKI MICROLINE® ML390 Matrix Printer
Dymo LabelWriter Thermal Printer Logo
456 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
