Question about PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive
I have an 8G Imation flash uSB. It has worked fine till recently but when I insert into port now it shows the files with hieroglyphic names and says it can't open them. Is there something I can do? Thanks a lot.
    Sergeant:
  • 244 Answers
I think you can defrag a usb drive, if it shows on your 'my computer' list of removable drives- you might try this- you can also run an anti-virus check on it, if you have an anti-virus prog. if that don't work, and the data is stored on your hd, then try re-formatting it.
if that don't work, toss it, and get a new usb flash drive!
good luck!
Posted on Oct 04, 2009
  • Edward Jennejohn Oct 04, 2009
    i think you can defrag a usb drive, if it shows on your 'my computer' list of removable drives- you might try this- you can also run an anti-virus check on it, if you have an anti-virus prog. if that don't work, and the data is stored on your hd, then try re-formatting it.
    good luck!
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Hello there. I can't view the files on my Imation Apollo M100 2.5 Portable HDD. I was able to use a few days back, copied and transferred some files to and from my netbook. But now, I couldn't...
change the usb and then check else if its working or not..check also if its working on any other computer..if its not even detectable at other computer as well then the hdd itself must be the faulty..contact the manufacturer
Aug 10, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Kingston datatraveler 8G shows write protection error, contain a virus outorun.inf, cannot save, cannot be formated and cannot delete. Please help.
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
Jun 01, 2011 | Kingston Digital DataTraveler 4000 8 GB...
My imation USB does not work ! When I insert it
scan it with a updated antivirus and then right click on it and explore it when it opens copy all the files in any folder on the drive and then format it and then insert the files
if u have still ur problem then call me
vicky
+919584011072
May 09, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Showing an error ''insert a disk in removable media''
Its happened for my Transcend 4 Gb pendrive. I format dat using ONLINE RECOVERY TOOL from Transcend. Now its workin :-) :-) :-)
Dec 16, 2009 | Electronics - Others
Pendrive not formatted
if u still having the same problem, follow these steps:
1.Insert your pendrive. open mycomputer, note the respective drive showing pendrive.
2. Then go to run and type cmd ( or go to command prompt)
3.It will show like: C:\> or C:\Documents and Settings\UserName>
4.Type the drive name of pendrive as shown in e.g
if drive is h: then type as
c:\>h:
h:\>format h:
it will format and ask for media name, you can give the name of your pendrive.
your pen drive is formatted. Now it will show the free space as 8G.B
Sep 13, 2009 | Transcend (589307) Media
Imation USB not reading in My Computer
Insert the device and restart the computer. Does it shows a "removable disk" icon in My computer? If it does, go to the properties and click unblock, may it's block. If that doesn't work, then just reformat.
Sep 05, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
I had problem with imation lock
how format flash imation 8 gb write protected
Mar 25, 2009 | Electronics - Others
Imation 4GB pen drive is not working................
you will have to re-install the drivers for it i think.
it seems like you pc is finding the drive but just can not access it.
Feb 25, 2009 | Transcend (589307) Media
I had run imation lock on kingston 4 gb and now its says "Please insert the device or run this"
its a little tricky, just try it
  1. unplug ur usb drive
  2. double click the imation lock
  3. when the message appear "Please insert the device or run this utility as privileged user" plug the flash/usb drive quickly
  4. USB will start working
  5. run the imation lock again and disable the password protection
  6. delete the ugly imation lock from ur system
i hope u find it use full, plz give ur feed back at: masood@inbox.com
Jul 28, 2008 | Computers & Internet
PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive Logo
268 people viewed this question
Top PQI Computers & Internet Experts
Arora Singh
Arora Singh
William Alequin
Are you a PQI Computer and Internet Expert? Answer questions, earn points and help others
