Question about Sharp AM-400 Digital Multifunction Printer
Sharp AM-300 multiF requires to check scanner lock and doesnt scan or copy
  • 523 Answers
You have to look for the scan buttom lock, sometimes its located where the papers out, or behind the machine, its small buttom to lock and unlock the scanner when you want to move it.
Posted on Oct 04, 2009
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
My copier AL 1631 is showing an error in the display. it is flashing the number "1" and after the leter "L". Please help me
Turn off the on, if it doesnt clear do this; Check whether the scanner drive is locked or the copy lamp.
Oct 24, 2009 | Sharp AL 1631 Copier
My hp 5610 all in one does not scan.
Maybe the scanner is locked. Open the scanner top and check just under the lid, you should see a white circular thing that says Lock / Unlock. Trust that was your real problem.
Let me know.
Aug 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner bar will not move to scan the paper to be copied.
a piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Scan head lamp does not move
the scanner lock could be on. This is located above the paper exit
trat. It has a knob with a picture of a lock. It shoulb be in the lock position. The scanner bar could be dirty. This is located under the copier glass.
Dec 01, 2008 | Office Equipment & Supplies
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
Sharp ar5127 copia eror slution
Check the scanner lock located under the scanner section on the left side. Change the position of it.
If it sitll locks the scanner could be jammed up by the cable. The scanner glass has to be removed to fix that.
Jun 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp al-1642cs
if scanner is not going all the way back you need to ck the home posinson senser it may be dirty.
Feb 05, 2008 | Sharp AL-1642CS Copier
237 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
