Sharp AR-5320 Black and White Copier
Problem for Sharp AR-5320 Black and White Copier
Sharp AR-5316E Error CODE U-2
By lankeshbhosl on Oct 04, 2009
I have Sharp AR-5316E but on display panel Error CODE U-2 is apearing continiously
Solution #1
posted on Oct 04, 2009
Not Rated)
goodgold
Rank: Wiz  Sharp Office Equipment  Expert
Rating: 84%, 144 votes
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
Was this helpful?
Yes
No
Popular Solutions for Sharp AR-5320 Black and White
Questions and Unsolved Problems for Sharp AR-5320 Black and White
Do you recommend Sharp AR-5320 Black and White Copier?
Answer
Answer
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is... (More)
Answer
sharp arm350-450 the imagistics versions adjusting of the printer void area lead & trail edge... (More)
Answer
SIr, I have the SHARP AR 5320E photocopier. How can i set the password to avoid the unauthorised... (More)
Answer
powersuply sharp ar-5320 14c471
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AR-5320 Black and White...:
Top Copier Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
