Question about Frigidaire Kitchen Ranges
Frigidare model mef352bgwd oven problems, gets up to temp and goes off
When the oven is started up it reaches temperature it will not come back on again. the elements check ok. does the sensor control this and when cold how man ohms should it show with an analog meter.?. simpson 260
  • gpnleigh Jan 04, 2009
    frigidaire mod.# MEF352BGWD The oven will preheat, but when it reaches the desired temp it beeps like when its ready then shuts off completely. I must turn the knob all the way off let it cool just a bit. reset the temp and start it again. when it reaches the full temp. it will shut off.
  • 183 Answers
SOURCE: Oven doesn't heat up
Problem is caused by out of calibration main oven thermostat or faulty (melted) function switch, only sollution check function switch for signs of melted or burnt connection other wise change stat. Regards Engineer
Posted on Jul 28, 2007
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
Amigaman
  • 248 Answers
SOURCE: Top element in oven not working
This "top element" is your broil element. It will only get red when broil is selected.
Posted on Nov 20, 2007
SOURCE: JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
Posted on Jul 01, 2008
  • 572 Answers
SOURCE: Frigidare oven model ples389ecc displays error
i think the clock is bad
Posted on Feb 06, 2010
Frigidaire Oven Problem
please post the model Number here..so i can look it up but just off hand there maybe an oven sensor (thermistor) problem this in inside the oven and tells the electronic ctrl board what the actual temp is in the oven it says 135 beacause it will until the temp reachs that after that as the temp goes up it will read 140 150 160 .. and so on until it reachs the set temp .. Is the oven getting hot and are there any fault codes coming up??
Jan 28, 2008 | Ovens
Oven won't heat accurately
Brad, your right on track. But I'd look toward the sensor first (The computer only does what the sensor tells it to do). I'll need the model number to find part numbers to help you further. The model number is on a sticker located on the oven body behind the lower drawer. It'll start with 3 digits then a decimal point the more digits (xxx.xxxxxxxx).
Sep 27, 2007 | Kenmore 96222 / 96224 / 96229 Electric...
Frigidare gas oven wil not get up to tempature
Hello - Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
Sep 16, 2012 | Frigidaire FGF334BG Kitchen Range
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
Ovens wont heat to temp
The reason to this problem can be due to the faulty
thermostat.
Sep 02, 2009 | Lincoln Conveyor Oven - 1133-000-A
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
GE oven
Yup...I believe this may have been an issue with some GE models. I seem to remember a problem where some models had problems staying lit after preheating. The fix was replacing the oven thermostat. Now...the normal cycle for an oven lighting is just what you described. The glow igniter will glow first, followed by the gas valve opening, followed by ignition. Once the oven reaches optimum temperature it is normal for the gas to shut off and come back on to maintain oven temperature. However, if this is going on in a frequent fashion with the oven never getting warm, your guess is probably a correct one. Good luck to you.
Jul 31, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
227 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Justin Duby
Justin Duby
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
