Question about Toshiba REGZA 32WLG66 32 in. Television
Have a tv in bedroom and want to tune sky into it on one of the channels, how do i do this
  • Toshiba Master
  • 11,800 Answers
You need a separate satellite receiver or an AV cable from another receiver (but this way you will see what's on the other tv without any control over it).
Posted on Oct 04, 2009
5 Suggested Answers
SOURCE: technika tv lcd 19-907 tuning in to sky in bedroom.
Hi, with regards the tuning in of the required station I started from the beginning again and after the digital channels had been automatically tuned in it asked if you wanted to tune in the analogue channels . I clicked on the yes button and it tuned in a number of channels and when checking through the channels I found the sky channel required from downstairs which is linked by an aerial connection.
AS Gordon Ramsey would say :------ telly tuned in DONE
Posted on Dec 15, 2008
  • 362 Answers
SOURCE: Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Feb 04, 2009
  • 325 Answers
SOURCE: have lost the link from sky+ to a second tv which
Hello K Agate,
In the main room where the Sky + is locate. With the sky remote press the following.
Services.
0,1,select
4 (rf)
Ensure that the RF power to set to on, and take a mental note of the channel number the RF is set to. I normally set this to 38 it is upto you.
Now check that the coax lead that links the sky+ box to the 2nd room is plugged into RF out 2 on the back of the sky+ box.
Now go into the other room and make sure that there is a red LED light on your magic eye. If there is then great. If not there may be a fault with you eye. A good way to check this would be to connect it straight into the back of you Sky+ RF OUT 2 port. This would also check to see if there is any fault with the coax cable feeding the other room.
Assuming that there is a Red LED light on the eye when its plugged into the back of the TV in the other room (not the one with the sky box in), This means that there is power getting to it from the Sky + box.
Put your sky box on the TV GUIDE screen. This will make tuning it in a lot easier.
in the other room with your tv remote press the following
Channel 6 or which ever number you want it on.(analogue)
then MENU on the remote.
Go to MANUAL STORE
Then if you go down to where it give you a C ** number just type in what you retrieved from the sky RF menu.
That should bring your sky up then all you need to do now is STORE.
That should be you all sorted out now.
Hope all goes well. If so then please leave a Thumbs up
Cheers Little Dish Fitter.
Posted on Oct 21, 2009
pjhislay1
  • 822 Answers
SOURCE: I have replaced an existing
if your trying to get sky on both tvs.....then easiest way is with a sky magic eye................ cheapest deals on ebay..
cheers
Posted on Apr 05, 2011
Hi my Son has upgraded his old tv in bedroom to a Bush smart tv model no DLED32287HDCNTDFVP. I installed the channels first time. I have freeview channels except I cannot get the Sky channel to show?
When you say you have freeview channels, and then say you cannot get Sky channels this is not enough information that you have provided, but
I presuming in addition to freeview channels you also have a Sky Satalite receiver which is no longer connected to your Tv or your sons tv Either way Sky satalite have 2/4 lines which means you can have four viewings providing multi rooms is bought from sky, and additional boxes are fitted.
Or you can have 1 sky box main Tv and no the spare cable feed at the back of the sky box you can feed another cable to another tv from that same box but it will be same channels But you can now change channels using magic eye receivers etc, in any room.
But the question I believe is you had freeview but no long can receive sky channels the information is a little vague but hopefully I have helped a little
Sep 05, 2017 | Bush Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
How do I tune sky tv into my new Toshiba television
If the TV set is on the same stand as the Sky box then you don't tune at all. Connect with either a HDMI cable or a SCART. Use the AV input on the TV.
If you mean you have a bedroom set, and Sky is piped around the house on RF, then that's something different.
Make sure your TV has an analogue tuner as well as the digital one used for Freeview. (check the remote for a TV/DTV button). Go in the the TV tuning menu, and do an Auto tune for both analogue and digital.
Sep 13, 2014 | Televison & Video
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
I have a sky hd+ box in my lounge and wish to make the sky work in my bedroom, I am happy to only watch what is on the lounge tv in the bedroom (not have multi room) thanks Nigel
Run a coax cable from the sky hd+ box at the rear from the RF2 coax port, and into tv in bedroom.
If you want to change channels, buy a magic eye from eBay for a couple pounds, enter sky settings, and turn power on to the RF2 output. this will supply your coax to bedroom with 9v which will power your magic rye
Oct 23, 2013 | Neet Cooler Trunk Organizer
I have 3 digital tv's one in the lounge/bedroom and kitchen for some reason last night, the tv's in the bedroom and kitchen lost all digital channels and the analogue channels were very poor to view snowy...
Loosing digital channels is equivlent to a snowy analog channel, check you cable connections, and splitters to the tv, since you have two of them out, it does not make sense that it is your tv. It is a conneciton in your cable line somewhere.
Sep 02, 2009 | Televison & Video
Hi Max,
Lone99star
Feb 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
Toshiba REGZA 32WLG66 32 in. Television Logo
135 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
