Question about Vehicle Parts & Accessories
Hi i have a remote start alarm and when i start it the cranking noise still goes on 2-3 seconds more than it should after the car is running anyone know if it can be fixed?
  • 10,515 Answers
It sounds like you have an aftermarket alarm in the vehicle that has been inactive or turned off at some point and has now decided to wake up and participate.Look under the dash on the drivers side for a bunch of wires that just look out of place. Follow them up. and usually the alarm module is shoved up in there out of site.
Pull it down so you can see it good. if it has gm on it, or viper. Just unplug every thing connected to it and your vehicle should start and be back to normal.
If it says something else. unplug every thing and if your vehicle doesn't start, then there is a thich wire going up your steering column that has been cut and the 2 halfs go to the alarm. Cut the wires going to the alarm and splice that thick wire back together and the vehicle will start.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 19, 2009
Car alarm goes off 30 seconds after disarm and open a door
Apparently the alarm is set to passive arming and, once you disarm it, it immediately begins the arming process and it is not registering the door being open. I'm going to go out on a limb and say that the alarm door trigger is wired to the dome light and the dome light is turned off; an issue that occurs with GM vehicles that have a dome light override switch. What's the year, make and model of the vehicle?
Sep 02, 2012 | AviStart 4400 2-Way Security / Remote...
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Car cannot start. Alarm will goes off.
Battery voltage is not always an indication of the battery health. Measure the battery terminal voltage under load. Check how it behaves whilst you are cranking the engine or when headlamps are switched on. If it drops drastically, some cells may be shorted. I also recommend checking the TDC sensor.
Dec 24, 2009 | 1992 Honda Prelude
2000 hyundai elantra alarm goes off where is the
There is NO kill switch on the 2000 Elantra... HOWEVER, there is a thing called the Key Fob (keyless remote entry system). There is, however, a system in place called the 'starter kill' circuit and it is activated when the burglar alarm goes off.... it's called the burglar alarm relay and it is activated to prevent the engine starter system from being used. There are three ways to get the engine started in such a circumstance... 1. use the key fob to 'disarm' the system... 2. put the key in the ignition and turn it to the 'RUN" position and wait until the alarm stops (horn stops beeping and the parking lights stop flashing), then the engine will start.... 3. pull the starter relay from the UnderHood junction box and bypass the starter circuit (key in ignition and in the 'RUN' position), jumper the starter solenoid circuit to energize the solenoid to start cranking the engine -- it should start then.
Oct 03, 2009 | 2000 Hyundai Elantra
My keyless entry remote stopped working so i had unlock the door through a cracked window.... the alarm went off, but when i started it, the alem didnt stop.... now when i dont lock it and open the door or...
yes the remotes do have batteries. how ever that might be your problem or the remotes lost its code for programing. step when turning alarm off---- if its a factory alarm put the key in the drivers door when the door is closed and lock then unlock it thats the manuel shut down for factory. step 2------- aftermarket alarm. look for a valet switch most likely it would be installed by the driver kick panel or by the under dash fuse box. when u find it put the key into the ignition. turn it to the run position. within 3 seconds press and hold the valet switch for 3 to 5 seconds you should here a confirmation chirp and the led light will stay on solid and wont blink give it a world let me know what happens
Jun 10, 2009 | 1999 Oldsmobile Aurora
Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
May 21, 2009 | 5900 SST 2-Way Security System / Remote...
Remote start on my viper alarm wont stay running
it is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
Jan 14, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Dec 28, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
1997 Sebring starts, then stalls
You need to disarm the alarm, the 2 problems are related, the start and stall is caused by the fuel pump interupt function of the factory alarm, you triggered it when you replaced the battery, The reset procedure is in the owners manual.
Nov 07, 2008 | 1997 Chrysler Sebring
Vehicle Parts & Accessories Logo
19 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
