Question about SanDisk Sansa e260 MP3 Player
Sansa e260: Firmware download problem
Hi. For the life of me I cannot get this firmware downloaded. Last time I had my tech guy @ work do it for me so I do know it's possible.
Basically...everything looks good to go, it downloads to 100% then I get this error message: "The installation failed. Please try again later." I made sure I was in MSC mode. What am I doing wrong??? Advice is greatly appreciated.
Thanks.
  • Anonymous Sep 29, 2008
    bin it sansa is not easy in anyform cannot gat music from sync media to player
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
انيك ابوش
Posted on Sep 28, 2008
Ive a e260 v2 . which ive had since 2009. I was very pleased with the player Someone said the other week that i should Update the Firmware . So i did download the firmware search and it uploaded it,...
Hi, it might not be from the firmware update that the volume gets low.It might be from the speaker already getting bad without you noticing it. you can replace the speaker too it might work out.
Also firmware update can cause it too. Updating with the wrong firmware ...
You can use the below link to know the right firmware update to use for you san disk sansa e260 mp3 player..e200 might work with yours..
kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
1. Download the SANSA Updater from:
sandisk.com/sandisk-support/driver-download-wizard.aspx
2. Install Updater
3. Plug in the SANSA e260
4. If it needs new firmware, it will tell you to download and install.
5. Follow directions on screen.
Hope it helped.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e260 MP3 Player
How do i update my SANSA e260 4GB, firmware??
http://www.sandisk.com/sandisk-support/driver-download-wizard.aspx
2. Install Updater
Sep 24, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Dec 01, 2008 | SanDisk Sansa e260 MP3 Player
Formatting the sansa e260
if you've already followed the below instructions, restart the computer once and then replug the Sansa player:
-Tha Mp3 Doctor
May 10, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 4gb Restarts over and over
-Tha Mp3 Doctor
Apr 27, 2008 | SanDisk Sansa e260 MP3 Player
Please help me!
or
-Tha Mp3 Doctor
Apr 18, 2008 | SanDisk Sansa e260 MP3 Player
yea do you do that and then open it with a screw driver and then pour a little water on the processing chip, that would fry the chip, then take out the chip and replace it with an pentium III and you should be fine.
Dec 23, 2007 | SanDisk Sansa e200 MP3 Player
Help! Sansa will turn on, go to the opening 'sandisk' screen and that's it
go to sandisk website and download a firmware updater
for your sansa e260
Oct 20, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260
Hi, I have the same problem but sometime is the left channel & sometime the right channel. I tested multiple headphones and it's alway the same problem. FYI the problem begin after a firmware update. With the original firmware the problem never append. It start with the firmware ver. 01.02.15E. Today I have downloaded the new firmware version (01.02.18E). I hope it fix this annoying bug. Bye
May 01, 2007 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
642 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
