Question about HP Pavilion dv9000z Notebook
Sending out email ok. incoming email sent to me does not register on my screen.
    Sergeant:
  • 244 Answers
Don't know what e-mail service you're using, but check if you have incoming filter set too high! also, check firewall settings! may be blocking incoming e-mail!
good luck!
Posted on Oct 04, 2009
I registered a few minutes ago. St top of the screen I saw a message "send email again". I shouldn't signed out but I did. How to I comply with ur request.
Not OUR Request as Fixya was not the site.
You need to find the Contact details for the site you were in, or just ignore the request.
What you can do is go back into your mail website and check in the Sent Items folder to see if it has been sent, or look in Outbox to see if it is stuck. Failing that it might be in Drafts, but unlikely.
If you can't find it, you will have to write and send the email again.
Oct 31, 2016 | Computers & Internet
Incoming emails are not appearing in the inbox folder of Microsoft Outlook 2010.
Could be your Outlook profile got corrupted somehow. If you use your account settings on another PC w/Outlook does the trouble follow? Or is it strictly w/your PC? Obviously, other profiles are working fine (your partner's). One solution might be to backup your .pst file to the C: drive or a USB drive, completely delete your old profile, and build a new one. Once your confirm that email is working properly, then attempt to reload your old .pst file to get all your old email back.
Something else you could try is to open Outlook in Safe Mode. This will run Outlook with minimal addons in order to eliminate the possibility that some sort of addon is the culprit.
You can use one of these methods to start Outlook using a command line switch:
Hold Ctrl key as you click the Outlook shortcut.
If you use Vista or Windows 7, type outlook.exe /safe in the Start Search field on the Start menu then press Enter.
Jan 03, 2016 | Microsoft Outlook 2010
Why doesn't it work correctly?
Also, make sure nothing is in your Outbox folder. If any emails are stuck in this folder, it will cause issues.
Can't get them to send my friend and email to reset new password
Facebook will only an email for resetting the password to the primary and secondary registered email. Your registered email should be in working order and consider checking the SPAM filter as well. Your email client could have automatically sent the email to the junk mail folder.
Jun 24, 2011 | Facebook Social Network
Email settings
you must have email account, also the POP address, and the SMTP with your username and password ready
Set up email account
1. Select Menu > Messaging > Email > Settings > New account > Add.
2. Enter a name for the email account, for example, Home or Office. Select OK.
3. Select Connect using > Edit and select the data account you created earlier to use with this email
account.
4. Select Email address > Edit. Enter your email address. Select OK.
5. Select Connection type > Edit. Select POP3 or IMAP4. POP3 is the most common.
6. Select Incoming server > Edit. Enter the name or the IP address for the incoming server. Select OK.
7. Select Username > Edit. Enter the incoming server username. Select OK.
8. Select Password > Edit. Enter the incoming server password and select OK. Leave this blank if you
want to be asked for the password each time you check new mail.
9. Select Outgoing server > Edit. Enter the name or the IP address of the SMTP server you use to send
email messages. Select OK.
10. Select Advanced settings.
11. Select Your name (not mandatory) > Edit. Enter your name and select OK. This will appear in outgoing
email messages.
12. Select Signature (not mandatory) > Edit. Create a signature to add to your email messages and
select OK.
13. Select Download S&R. Choose what to download when receiving new email messages:
• Subjects only – receive information such as sender and subject before downloading the whole email.
• Up to size limit – receive the whole email. Select Size limit to set the maximum size to download
when receiving new email messages.
• Subjects & text – Only for IMAP4 users. Receive the subject and text but not attached files.
14. Select Check interval (not mandatory). Choose how often you want the phone to connect to your
email server and check for incoming email messages.
15. Select Push email. Only for IMAP4 users. Select On for full email notification functionality or Off to
disable the functionality. See Using push email for full email notification functionality on page 7.
16. Select Allow connection > Edit. Select Any network or Home network.
17. Select Copy outgoing (not mandatory) > Edit. Select On if you want email messages sent from your
phone to be sent to an additional email address of your choice. This way your sent messages are
copied and can be saved for future reference.
18. Select Encryption > Edit. Choose whether your email messages should be encrypted.
19. Select Outgoing. username. If requested, select Edit enter the outgoing server username.
20. Select Outgoing. password. If requested, select Edit enter the outgoing server password.
21. Select Incoming port. If needed, change the port for the protocol you are using.
22. Select Outgoing port. If needed, change the port for the SMTP protocol.
and the other is
To write and send an email message
1. Select Menu > Messaging > Email > Write new.
2. Select To: to add recipients and select Add. There are three ways to add an intro sentence:
• Select Enter email address. to enter an email address.
• Select Contacts look-up to retrieve a recipient from Contacts.
• Select an email address from the last used recipients.
3. To add more recipients, select To: > Edit select Cc or Bcc and select recipients to add. When finished
selecting recipients select Done.
4. Select Subject: to write the subject.
5. Select Text: to write the text.
6. Select Attachments: and select the attachment to add. Add more attachments the same way.
7. Select Continue.
8. Select Send to send the message or More to view options.
To receive and read email messages
1. Select Menu > Messaging > Email > Inbox.
• Select Send&rec when the inbox is empty or
• Select More > Send & receive to download new messages.
2. Select a message and select View to read it.
To reply to an email message
1. Select Menu > Messaging > Email > Inbox. Select an email message in the inbox. Select More
> Reply and select:
• Yes – to include the original message in your reply or
• No – to exclude the original message.
2. Write your message select OK > Continue.
3. Select Send to send the message or More to view option
Mar 08, 2010 | Sony Ericsson W350A Cell Phone
Emails not reaching destination although they are in 'sent box'
This can be due to your destination server's security settings that are set to reject incoming Yahoo emails, that were largely used by spammers in the past years.
What you can do is call the person you are trying to reach by email, and ask him if there was any security settings set by his company or ISP.
Frequently companies are using "blacklists" in order to block junk mail. You are then in a "false positive" situation that is hard to solve. Try to send from another email adress to see if that still happens.
Hope this helps
Aug 05, 2009 | Yahoo Mail
Unable to send
thank you for choosing Fixya.com
please check if the address of the receiver is correct..
make sure that it is not in the capslock mode.
e.i marrk26@yahoo.com
Feb 19, 2009 | Yahoo Mail
Problem with sending emails on the iphone
What email provider are you using.
Also check who is your incoming mail server but the best way to do this is to delete your account and register it again on iPhone push mail.
Thank you, Apple Care Technical Support
Jul 02, 2008 | Apple iPhone Smartphone
Problems sending and recieving mail in Outlook 2003
I am recieving some of my emails in my sent box not my inox.I am also using Outlook 2003
Nov 13, 2007 | Microsoft Outlook 2003 for PC
HP Pavilion dv9000z Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
