Question about Speed Queen AWS52NW Top Load Washer
How do you dissasemble a speed queen commercial washer gearbox? Does not rotate correctly when in use. Have isolated problem to gearbox. Would like to dissasemble to analyse further.
    President:
  • 1,304 Answers
In orde to open it
you will need specalty hub tools to get it out
Posted on Oct 05, 2009
Speed Queen front load commercial washer - error code ed44. What does this mean/
Overcurrent Shunt Detection,Circuit Fail Error
Hardware failure. Unpower to clear error. Replace drive board if error persists.
May 04, 2017 | Speed Queen Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
We have coin operated washing machines is there a sheet to show us how to change the price
http://www.pwslaundry.com/c-295851.4-commercial-speed-queen-swfx71n3000-front-load-washer-parts-for-repair-service.html
You want the one that says Programming...
Dec 31, 2012 | Speed Queen Swfx71_N3000 Commercial...
Speed Queen model no.AFN50RSP111TW01 Washer makes humming sound all the time in off position,i am being told by dealer that its the transformer which is normal,replaced transformer and still hums,unplugged...
Usually a transformer hums when it does not have the proper voltage being supplied to it. I would check this first. If the voltage is correct contact a parts supplier and request a new transformer. Speed Queen has a great parts warranty. As Speed Queen is really a commercial machine it is not unusual to have them make more noise than other manufactures.
Dec 18, 2010 | Speed Queen ATS90AWN Front Load Washer
Hello. I have a commercial Speed Queen top load washer and while filling with water, it does not stop without opening the lid. I have replaced the pressure valve and checked the hoses and still no fix. Any...
try checking the where the water hoses connect that water valve is where the water is shut off, turn off the water facuet undue the hoses and look inside the valve does it have calcium buildup? or sand in it? if it does you will have to pull the water valve to clean it in order to get it to work correctly. Let me know if you need more help and thanks for using fix-ya.
Jul 01, 2010 | Speed Queen AWS44NW Top Load Washer
Bearing or gearbox noise on spin
It is a pleasure for me to offer some assistance to users all over the world. The problem you are describing to me is a very common for any amana, speed queen washers. The tub seal leaks and washes the lubricant from the upper bearing making the roaring noise in spin. The bearing needs replacement now, also the tub seal comes as a kit to rebuild all the sealing surfaces. It also does require a complete dissasembly to install the new kit plus the bearing. I would charge 3 hours labor @ 75/hr and the parts would be around $100 for the hub-n-seal kit and the bearing. However you may want to consider a new machine with a better warranty (extended warranties are a MUST these days......BUY ONE with any new appliance. Hope this helps let me know if you have any questions. Unfortunatly these Speed queen design washer have a myriad of design problems and this is only one of them.
Jan 01, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWS52NW Top Load Washer Logo
205 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
