Question about Sony Playstation 3 (PS3) Console
No picture for ps3,i went to service menunand did something wrong
I cant get a picture from my ps3, i went into the service menu and went to restart system by mistake and now it wont work
    Sniper:
  • 64 Answers
You probaly turned hdmi on or off i dont know what your settings is,
you can turn your system settings back to factory default using the Safe Mode.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
    no picture for ps3,i went to service menunand did  - safemode2.jpg //
Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
Posted on Oct 04, 2009
I have just purchased a 46" samsung led tv @100hz
Try resetting the entire video/audio settings to default. The blur on the picture may indicate that your motherboard is going bad. Recently there was a customer who had the same problem. It was his board. When we tried the AV cables, the blur went away. We tried different HDMI cables and the blur was still there when using HDMI output. It wasn't the TV, and it wasn't the HDMI cables. It was the board going bad.
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
Cant access the ps3
this is happened cuz ur PS3 is over heated u have to cool it and clean it, use the hair dryer to get the dust out of it and try to keep ur PS3 cool all the time, if it didnt work when u start ur PS3 keep holding ur finger over the bower button for 5-7 mints u will hear a double beep sound remove ur finger then ok u will see a menu with a few options in it choose the first one restart PS3 also if it didnt work do it all over again (the problem that i cant rem. what that menu contain :S ) but any way check if there is a repair PS3 option ok. or if u PS3 start normally by accident go directly to the settings menu and go down and choose repair PS3
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
Screen of my ps3 went black, i cant see the menu
While the PS3 is off (red led)
Hold down the power button until you hear the second beep, quickly release.
That's it!
May 13, 2009 | Sony PlayStation® 3 (80GB) Console
Major Problem, Cant Fix
well you can go to playstation.com and go to updates
and if yyou have a membory stick or anything that can hold info put the first update on it and then put the update on the ps3 after that you have to reboot everything and restore the ps3 it will be like you just bought it but youll still have your pcn account
May 18, 2008 | Sony Playstation 3 (PS3) Console
Please help!!!
Check the settings and find out what went wrong.
Apr 26, 2008 | Sony Playstation 3 (PS3) Console
Brand new PS3 system and cant play ratchet and clank cause not enough memory
hi, my sons did the same. i went into the save data files and deleted the ratchet and clank data then restarted ps3 and put the game back in. this time it worked and we've had no problems since.
Jan 03, 2008 | Sony Playstation 3 (PS3) Console
No picture on tv screen.
Had the same problem. When I turned on the console, the screen went a bit fuzzy at first and then remained blank. There was no sound either, but I could still turn it off with the controller. I checked all the connections and even plugged it into another T.V. I have now discovered the problem! The scart connector which came with the PS3 wasn't working properly. Didn't have the prob before because I wasn't using it. Hope that this helps. If not, try holding the power button down for a few seconds after turning on the system. You'll hear a beep noise and the system will try to adjust its AV output or something. Worth a try anyway.
Dec 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
122 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
