Question about Sony Televison & Video
After this new digital update my sony trinitron KD32DX40U wont
Pick up all the new tv station. What can I do. Will I have to buy a new Tv.
  • Sony Master
  • 11,800 Answers
No need for a new tv. All you need is a digital tuner. If your tv has one (all the recent models do) all you have to do is to plug the antenna into it (if it has a different entry) and do a new scan. If not , buy one , connect it to the tv like you would connect a dvd and do a scan They were given almost for free in the US.
Posted on Oct 04, 2009
My digital tv will only pick channel 10, abc and sbs, even though it used to pick all channels?
U trying to pick up all free AIR DTV tv stations wright?Yes.This problems u have a weak airial antena.Buy a better antena like a Digital antena or a roof antena for hook up.Tries again,will pick up all DTV free AIR tv stations.
Apr 03, 2011 | Televison & Video
Sony tv wont start up???
It seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). Do you hear any clicking sounds?
Or else it could be that the CRT tube is faulty and will need to be repaired/replaced.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise.
Hope that helps!
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I connected an antenna to the tv that i bought from walmart $30. But tv cannot find any channels at all.
If you live in the city you should be able pick up to one three channels on the indoor antenna, but if you are outside of the general viewing area you won't pickup anything. Antenna's of this sort have a very short range when it comes to tv signals, it is also possible that your antenna is not digital ready, which means any station broadcasting a digital signal you won't be able to receive.
Dec 22, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Need disconnect cable to over the air antenna How from cable to air
Need to buy a Digital Converter box.Hook up to get free air tv.Because this a CRT-Tube is an analoge tv.
Just follow the instructions came in with the Digital Converter box to set up it simple.Just remember go in the menu pick Air u not in Cable.Just scan than u get all the free air channels.
Feb 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-28DX30U. my tv wont re-tune!? I had digital channels before the switchover!? Do i need to buy a digital box? It has intergrated digital tv!?
It's probably curtains I'm afraid. The software in this TV is only compatible with the old standard (2k) and not the new standard (8k). Sony aren't releasing any updates so you'll need a digibox (or a skip!)
Dec 02, 2009 | Philips TV Tuner Video Capture PCI Card -...
I have a Sony FD Trinitron WEGA KV-27FS100 TV
You will need the converter if you are dependent on broadcast reception; in other words, use an antenna with your set. Cable and satellite sources may or may not 'go digital' at some point in time so if you are using one of these, check with your cable or satellite company.
If you decide to buy one of the pretty, new flat panel sets, buy the converter and DON'T toss your Sony. Store them in a dry place as backups. The flat panel sets are crapping out all over so you might do without TV when it fails.
Apr 07, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sound goes in and out
if you want to connect through cable , go on the net,
cable remote codes are 031,001,002,003,004,005,006,007,008,018,022,032,
and tv remote codes 001.
for the procedure go to sony programing technicail support on the net, a problem will be solved.
Apr 01, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
I have a Sony trinitron tv model no. KD32DX40U. When trying to turn tv on the red light below the on/off switch continues to flash red twice and green once when trying to switch on. Because of this tv does...
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.. if this did not work then check with other power supply unit ....
Good luck..
Aug 01, 2008 | Televison & Video
36 inch sony wega trinitron
I had the same issue earlier this week. 4 year old sony trinitron wega 32 in. I was told by Sony to call technician to repair and have called tech....could be anywhere from $200-$300 repair. I did research the blinks (google "sony blinking codes" to find out what each means) Ours was 6-7 blinks which meant power surge to tv. I advised to Sony that i saw many of the same issues with many of the newer tv's and suggested a recall issue--they denied and where no help.
I will buy a new tv now--definitly not a Sony.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
