Question about Panasonic GigaRange KX-TG5480S Cordless Phone (KXTG5480S)
Expansion handset for Panasonic KX-TG5480s
I want to expand my unit by adding an expansion handset. What model is compatible with the KX-tg5480s ?
Thank you.
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
  • 2460 Answers
SOURCE: Is tha possible to get 25 single lines on 16SLC card(50 pin)
The 25-pair Amphenol connector is just something the industry uses because it's standard and easy. In a TDA system, the 8-port C.O. Trunk card uses the first 8 pairs, a 16-port the first 16 pairs, an 8-port Pana station card uses the first 24 pairs, 3 pairs per extension. The last pars don't have any hardware behind it and are connected to nothing.
The only phone system that I remember where all 25 pairs are used is a 1a2 10 button set and, maybe a Comdial system where the 25th pair is the common audible for station 17 :-)
Posted on May 22, 2009
SOURCE: Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
Posted on Jul 28, 2009
SOURCE: handset volume on Panasonic KX-TGA101S is too low
Thanks for the user manual. This is the only place online I could find it...the other manuals are for installation only. I learned to push the up or down arrow on soft keys to make volume louder or softer. They have changed the page number. I found this on page 16.
Posted on Jun 03, 2010
  • 4719 Answers
SOURCE: I want the user's manual
The handset manual is here: (you'll need to rate the product or enter security code to download).
I hope this helps.
Posted on Jul 28, 2010
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
0 characters
1 Points
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Forum which handsets are compatible with the panasonic TG7120?
According to the manufacturer's information on the product, KX-TG7120, page (at, the unit will accept up to 5 additional Panasonic KX-GA711 handsets.
I hope this helps.
Mar 09, 2013 | Panasonic KX-TG7120 Cordless Phone
There is a section on setting the number of rings in the manual for the base unit on page 28. You can download it from here:
c:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.pngc:\documents and settings\bruce\application data\pixelmetrics\capturewiz\lastcaptures\2010-04-21_15-45-33-014.png
Apr 21, 2010 | Panasonic KX TGA270S Cordless Expansion...
Can't register Panasonic KX-TG6051 handset
Press (menu 00, reg) an press locator for 3 secons--- than press ok in you phone.
Aug 01, 2009 | Panasonic KX-TGA600B Cordless Expansion...
Difficulty adding a fifth KX-TGA939T handset to the system
The Best Buy store sold me the wrong model for that system !
May 19, 2009 | Panasonic KX-TG1033S Cordless Phone
Dial tone hanging
There are two wires going to your phone. Inside the wall jack, switch the red and green wires and the keypad should work .
Dec 10, 2008 | Panasonic GigaRange KX-TG5480S Cordless...
Panasonic GigaRange KX-TG5480S Cordless Phone (KXTG5480S) Logo
35 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
